603,898 active members*
5,588 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > another servos V/S stepper V/S R&P V/s ballscrew thread
Page 1 of 2 12
Results 1 to 20 of 36
    Jul 2006
    1256
    I was convinced to go with R&P and steppers.After seeing Granite Devices servo drives changed my mind.
    With R&P it appears 20to 1 gear reduction is necessary with servos while with steppers a simple 3to1 belt is sufficent.
    Rather than go on and on.
    R&P is for steppers.
    Servo is for ballscrews with the pitch required.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Dec 2003
    24260
    That is OK until you come to retrofitting something like an older Linde where the gantry weighs upward >300lb with 4 oxy/gas torches and maybe a plasma torch added.
    With AC/BLDC servo's having a constant torque up to their rated rpm of 6000~10,000 rpm, high reduction allows the economic sizing of servo's on something like this, especially if you want 1000 IPM rapids .
    I have found there is no hard and fast rule.
    Al.
    Albert E.
    May 2005
    2502
    I've seen guys juggling torches in Hawaii. I even saw a guy juggle chain saws in a video.
    Haven't seen 4 flaming torches and a plasma flying around at 1000 IPM yet.
    Sounds like fun. Where can I see the show?
    :banana:
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Jul 2006
    1256
    servo or not
    Hi Al thanks for the information.I did not realize servos had constant torque.I would assume setting feed rates and rapids would be much simpler than steppers.Granite Devices servo amps and Keling brushed DC servos sure look good as price/performance.Will a servo work on R&P without huge gearboxes?
    I must do more research to have better understang .
    BTW Al your avatar looks like you may be very young.You should really quit smoking
    Larry
    Dec 2003
    24260
    Quote Originally Posted by lgalla View Post
    Gearbox ratio depends alot on gantry weight, some reduction is required to economically size servo's.
    Obviously the high rapids are not cutting speed but between parts or plates.
    Larry
    I've been told that before.
    Al.
    Albert E.
    Jul 2006
    1256
    (flame2)(flame2)Bob,glad you chimed in.
    I suppose your reference to would like too see 4 torches rapid at 1000 ipm refers to the problem they may blow out and where would Al and I get a light!
    BTWBOB how did the E/G work out on the mill fill?
    I recently did a display at a local trade show for Tosiba Machine tool.They shipped their mini mill,the smallest machine they produce.40,000Lbs/40HP.
    No E/G!
    Jul 2006
    1256
    servoism
    Are servos less costly than steppers?May be checkout Granite Devices dual drives.http://www.granitedevices.fi/index.p...c-servo.1drive Will power 2 servos on the X and one more drive will power Y&Z.The cost would be around $150 per axis about the same as steppers.
    Keling has DC servos for about $100.I do not know if they are usable with the Granite Devices dual drives.Basically it appears servos can be more cost effective than steppers.
    http://www.kelinginc.net/ServoMotors.html
    Larry
    May 2005
    2502
    No E/G!
    I'm very happy with my E/G. The machine is solid. If I had it to do over, I'd do it again, and probably fill even more of the column!
    Cheers,
    BW
    Sep 2004
    1207
    Larry
    The DualDC drive was developed using Keling servos (Nema 23 and 34) as test motors, so the perfect matching is guaranteed.
    DC servos are generally a good choice for machine tools as their high inertia iron rotor provides stability against cutting forces & inertial loads. AC/BLDC servos start shining if extreme speeds & accelerations are required (>3000 rpm & low inertia). In heavy industrial use they also benefit from longer life time.
    In my opinion rack & pinion is not very good choice for machines where cutting forces are present. It is one of the least rigid solutions.
    Jul 2006
    1256
    crash
    Thanks guys for the answers.A recent computer crash wiped out all my research.Hope I can pick your brains.
    My gantry weight is max 500LBS.It is 12"x4"x1/4"x7'.I cut 18mm Finnish birch,5'x5' for speaker enclosures.From experience 400ipm cutting is over max.How many watts of servo do I need for X axis to move this gantry.Ballscrews are OK as C-7 is OK.I assume a one inch screw,one inch lead is necessary to reduce the RPM and not have whiplash.C-7 screws and support blocks are reasionable priced here.http://stores.ebay.com/linearmotionbearings.
    Tero since my ply comes from your country are you experinced with it?
    Al,do you have any suggestions as to the gear ratio or ball screw pitch required for the cutting speed ?
    Thanks guys.
    Larry
    Sep 2004
    1207
    Larry,
    The power demand question is difficult/impossible if there is no estimate of cutting force. My guess is that cutting forces probably are between 50N and 500N on most DIY machines.
    You can definitely find quality plywood from Finland I have also built some speakers but I used MDF since I coated the speakers afterwards:
    http://www.students.tut.fi/~kontkant/audio.php.html
    Jul 2006
    1256
    Hay Tero,I use 18mm birch for cabinets as they are used on the road.MDF is probably the best choice for home cabinets.I attached 2 pictures.One is a 28Hz subwoofer,it weights 250 Lbs.The outher is a stage monitor.To day I had the side panels of the monitor cnc'd on a friends machine.21 parts on 1 60X60 birch.He ran the machine almost 800ipm with a 1/4" bit.Time for one sheet was 10 minutes.By template and hand router it could take me 10Hrs.
    Have a good evening Terro
    Larry
    Jul 2006
    1256
    screwd up
    Confusis say...now that I consider ballscrews me all screwed up.
    Need help in translation.
    TPI is threads per inch?
    TPI is travel per inch?
    TPI is turns per inch?
    starts?
    To be specific and throw another log in the fire.(flame2)Metric?Suppose one has metric screw 2510.What this mean?At 72" long what is max rpm and ipm?
    Are 2 nuts better than 1?Is the load rating doubled with2?(nuts)
    Much happyness for your informed reply.
    Muchas Gracias Amigos.
    Larry
    Will consume Holstien Festbock's,waiting for answers.
    HAD is Holstien Aided Design
    35494
    TPI is usually threads/inch.
    I believe that 2510 is 25mm screw, with a lead of 10mm (10mm per turn).
    Go to www.nookind.com and check out their ballscrew catalog. Should have all the info you want. Max rpm depends on the method used to mount the screws. See their critical speed charts.
    Sep 2004
    1207
    Nice speakers Larry!
    Here are some of useful calculators for transmission design:
    http://translate.google.com/translat...ml&sl=sv&tl=en
    Jul 2006
    1256
    more confused
    Thanks for the calculator links guys.
    Rather than going into detail math
    Long ballscrews 8or9' are going to whip like a skipping rope unless the lead is 1" or more and1"dia.I can get 2010 screws for $200 with the end blocks but the ipm would be like watching the kettle to boil.Going back to R&P,the lead appears to be 3.14" per turn and need 10to1 or 20to1 reduction at $400 just for the gear boxes.
    On an outher note my friends 5X10 router has a 7'Y axis ballscrew at 1turn per inch.and cuts at 600 to 800 ipm.If you check the Nook critical speeds chart this would be skippen like a rope.
    Larry
    The more I know,the less I know!!!(chair)
    35494
    Larry, have you checked out the Mechmate? They are using 3:1 or 4:1 belt reduction and rack and pinion.
    Jul 2006
    1256
    gerry good link.will probably take a week to digest.Are servos usable in this type of drive?Steppers have a narrow torque curve while servos appear to have constant torque v/.speed. Would servos be a good choice?The forum appears to be in favor of steppers rather than servos.Being a wood hacker .,0156 is accurate enough or 1/64"
    Larry
    35494
    For best performance from servos, you'll want closer to 10:1 I think, although if sized correctly, you may be able to get away with 4:1. I don't really know, though.
    Jul 2006
    1256
    I must ask Al the man.When using ball screws is the pitch similar to gear reduction?If I have a 2510mm screw does the torque multiply?Say I have Keling 1125oz-in peak torque DC servos,what would the torque be with 2510 screws?Actually any one can answer.I aimed the post at Al as he said reduction can save on the servo required to move the load.I am leaning to wards using ballscrews and servos.
    Al,Anyone told you,you smoke too much?Not me!I only smoke two a day,packs that is.
    Larry
Page 1 of 2 12
  1. Stepper or Servos?
    By gavztheouch in forum DIY CNC Router Table Machines
    Last Post: 05-28-2009, 07:02 PM
  2. thread outlining ballscrew/rails/accuracy etc?
    By blau_schuh in forum DIY CNC Router Table Machines
    Last Post: 12-30-2006, 07:44 PM
  3. Servos or stepper
    By freak_brain in forum Servo Motors / Drives
    Last Post: 02-06-2006, 10:03 PM
  4. strange bearing preload thread on ballscrew
    By mxpro32 in forum Benchtop Machines
    Last Post: 03-22-2005, 08:23 PM
  5. Servos on x/y - Stepper on z - will it work?
    By WoodSnarfer in forum Servo Motors / Drives
    Last Post: 11-17-2004, 01:12 AM
