603,894 active members*
2,861 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > engraving around a cylinder G107
    Aug 2004
    309
    Could someone get me up to speed on engraving text around a cylinder with G107 and G47?
    I would like to use "g47 P1 (###) " to engrave sequential serial numbers around 2" diameter tubes
    I am familiar with engraving and am in hopes it can be wrapped
    Jul 2005
    12177
    Have you read your manual? Any linear axis can be cylindrically mapped to any rotary axis (one at a time).
    Aug 2004
    309
    I have and was hoping for a simple example , I am just a little fuzzy on how the g107 line should be written
    If my current g47 line reads as follows , what would the g107 line before it read ?
    G47 P1 X9.5 Y0.0 I90. J.15 R.05 Z-.01 F20. E4. (####)
    Tube is 2" diameter , would it simply be G107 A0 X0 R1.
    Aug 2004
    309
    OK got it , the axis you want to swap to the A axis goes on the g107 line , some how that just didnt translate in the example in the manual, very simple now that I have a grasp.
  1. G107 Cylindrical Milling on Oi-TB
    By lowehardware in forum Fanuc
    Last Post: 08-12-2010, 11:27 PM
  2. cylinder
    By copperhead4321 in forum Solidworks
    Last Post: 05-13-2008, 04:20 PM
  3. G107
    By rajeshtikar in forum G-Code Programing
    Last Post: 10-22-2007, 04:14 PM
  4. g107 on the haas
    By ultrapeter in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-06-2007, 02:15 PM
  5. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
