587,319 active members*
3,382 visitors online*
Results 1 to 6 of 6
    Jun 2007
    394
    Z Level Rough
    I want to use the Z Level Rough 3 Axis toolpath to rough out a small part. I need to start with a 3mm end mill and rough the pocket and then switch to a 2mm and a 1mm.
    Question: How do I avoid machining material which may have been removed by the previous tools?
    Dec 2008
    4548
    Use a top and bottom of job setting. Be careful to note that the z level rough is looking at the "material to remove" and not the surfaces being machined. The toolpath will not make an extra step at a "lessor than step down value" to reach the "bottom of job" setting, so the next tool may have a bit more than the defined step down, unless you set the tops and bottoms to match the step down increment amount. Some imported 3d solids will carry "bounds data", somethiong like .002, so this has to be accounted for when setting your tops and bottoms correctly on the first passes.....
    Also, rule #2.... Dont mention Z-level rough anymore. Use advanced rough.
    Jun 2007
    394
    I have been trying to create an Advanced Rough toolpath but it keeps ignoring the solid model and removing parts of the model I need to keep??
    Mar 2007
    207
    fidia, if you can post your program ... "They" will be better able to help... or get a clear picture.... I can't quite picture what your doing... But I have found with a few parts... Even if they are solids.. extract the edges and machine as if they are 2d
    Using CNC Masters Supra Knee Mill, 4 Axis vari speed. Bob Cad V-23, V26, Bob Art
    Dec 2008
    4548
    Quote Originally Posted by fidia View Post
    Be sure to select the entire model for the toolpath and constrain it with boundries. You cant just select some surfaces. It wont know where the other surfaces are.....
    Dec 2011
    361
    Fidia can your provide a part to review. If you can't post it on the forum, you can PM me and I will take a look at it.
  1. X6 Mill Level 3 High Speed Core Rough
    By seijack in forum Mastercam
    Last Post: 09-29-2012, 09:32 PM
  2. rough out
    By Machineit in forum BobCad-Cam
    Last Post: 05-17-2012, 02:35 PM
  3. Problem milling Z-Level rough
    By JHren30 in forum BobCad-Cam
    Last Post: 02-07-2012, 07:58 PM
  4. Can't establish geometry for Z level rough.
    By klrskies in forum BobCad-Cam
    Last Post: 02-09-2011, 09:57 PM
  5. Z Level rough with multipule rough tools
    By mbi in forum FeatureCAM CAD/CAM
    Last Post: 02-26-2010, 05:45 AM
