588,685 active members*
6,208 visitors online*
Results 1 to 5 of 5
    Jan 2007
    5
    Hitachi seiki seikos III
    Hi All
    I have a Hitachi Seiki VK45 with Seikos III Control , I getting alarm “ can not edit ( MDI running) “ in MDI mode. Can You help Me reset it
    Thank You
    you d get more consistent help posting the same question only once
    what is it you are trying to do in mdi mode
    looks to me your trying to edit in mdi mode ,you can t do that
    Jan 2007
    5
    Hi Dertsap
    Present I can edit new program in memory mode and then machine running no problem and DNC is same. But in MDI mode after I type any G-Code or M-function and then press Insert button, I just getting alarm "can not edit ( MDI running) “. can you help me ?
    Thank You
    Dec 2006
    7
    Exclamation help
    hi, my name is Milton Suarez, and i work in a manufacturing plant. I have two HITACHI HT-50G, with SEIKI-SEICOS A10L control. We were uploading a part programm, and there was an electric overload between the p.c and the cnc...obviusly, the port for comunicate both, was damaged, and since that moment up to now, we couldn´t transmit anymore... neither uploading nor downloading. We had the same problem in another machine with Fanuc control, we solved it changing the port conection in the control from the RS-231 com 1 to rs-232 com2... in this way, we continue transmitting without problems. My question is, do Hitachi machines have other COM port as alternative? I opened the back gabinet, and i saw that there is a label where you read "RS-232 C2", but it belongs to a printer, and the conection is not the same as the common RS-232 serial 25 pin conection.
    As you see, i´m lost. i need to transmit again, i don´t know if i could use this other port, and if not, i´m afraid that i not be abble to fix the broken port.
    Any help that you could give me, is the most welcome.
    Thank you !!!!
    Nov 2012
    fix for “ can not edit ( MDI running) “
    this is a little late, but i needed to fix this problem this morning. to fix: go to edit, -> program -> program list -> condense.
  1. Hitachi Seiki Seicos
    By Enda in forum Fanuc
    Last Post: 12-15-2009, 06:14 PM
  2. Hitachi Seiki with Yasnac LX1
    By besc in forum MetalWork Discussion
    Last Post: 12-21-2007, 03:35 AM
  3. Hitachi seiki seikos III
    By dungvp in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-20-2007, 11:10 AM
  4. Hitachi Seiki
    By cre8tunes in forum Community Club House
    Last Post: 11-18-2006, 02:40 AM
  5. Hitachi-Seiki HG 400III
    By STCman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-06-2006, 05:41 PM
