588,666 active members*
5,941 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 BeltDrive (L-Style, V Belt or MicroRib J belts)
Results 1 to 5 of 5
    Jan 2009
    16
    Gents-
    I've learned immensely from everybody's input on this forum. To give back, I've compiled all my thoughts on the G0704 belt drive topic in this video.
    https://youtu.be/0sSs5_kh4OE
    Styles of belt drive tested where, L-style timing belts, V belts, and MicroRib PolyV J belts.
    In the end, if using the stock motor, very reliable success can be achieved with a Microrib Poly V belt with Delrin pulleys. Cost of material to make the pulleys was about $5 bucks and belt was $5 bucks. Catch the end of video to see the hogging power, no slippage at-all with stock motor.
    Hopefully this helps someone else not waste time failing:cheers:.
    Crash
    Dec 2012
    62
    Re: G0704 BeltDrive (L-Style, V Belt or MicroRib J belts)
    Please add links to where you got the belt and the model number.
    I realize now that you made the pulley.
    Jan 2009
    16
    Travis-
    I had the belt on hand so not sure where it came from. But it is a 140J6 Poly V belt.
    Matt
    Quote Originally Posted by travis_cnc View Post
    May 2009
    33
    This is a really nice video sir.
    I never have any issues with a v-belt and I run some fairly big tools with a reasonable sized 14A BLDC motor. My pulleys are aluminum. I don't even run the tension all that tight, I set it by hand and generally back it off a bit to add a tad bit of slack in the belt. The multi groove is nice, but the v-belt should be more than enough.
  1. Clearpath servo size recommendations for G0704
    By wolfmentality in forum Benchtop Machines
    Last Post: 01-26-2019, 05:01 PM
  2. Partner 1D. Removing X & Y Belts and pulleys.
    By sen2two in forum Milltronics
    Last Post: 01-23-2019, 11:40 PM
