587,514 active members*
2,976 visitors online*
Results 1 to 7 of 7
    Nov 2009
    6
    need help rover biesse 24
    hello I have a rover biesse 24 and it liked to set up some auxiliaries that exist for these you conspire and they are mounted in the cars that arise and they serve so that to put the pieces on top don't play in the suckers and when if it puts her conspires in work go down and the piece is in the suckers...
    somebody gets to some pictures of those applied pieces in the it conspires... thank you...
    Nov 2009
    6
    foto
    Nov 2008
    37
    Didnt understand any of it...can you try in some better english? I was operator on rover 23 , maybe can help
    Nov 2009
    6
    Quote Originally Posted by majstor76 View Post
    thanks for your help...i need some pictures of detail of those pieces marked by me in that picturer to see as that this set up for me to set up because to 24 that I work she doesn't have
    thanks...
    Nov 2008
    37
    Sorry , cant help you. I removed those lifters from Rover to be able to get rails closer
    Nov 2005
    172
    I am not sure I fully understand, but if you are trying to retrofit a machine with the lifitng bars it is somewhat of a detailed project...several mechaincal, pnuematic and PLC additions will have to be upgraded. If you are looking for replacement lifting bars, I recommend to customers they simply reverse engineer ( measure the ones they have ) and make a program to machine replacements.
    Hope this helps!
    Mark T.
    www.cnccustomservices.com
    Nov 2009
    6
    thank you for the help but I have an assembly outline but he would like to see detailed pictures to have the certainty that the assembly was correct but for this week I will put pictures here of mine conspires.
    thanks to all by the help.
  1. Need Help Biesse Rover 13
    By Christiaan in forum CNC Machining Centers
    Last Post: 09-15-2020, 02:42 PM
  2. Biesse rover
    By eng_semsem1980 in forum Biesse
    Last Post: 01-06-2016, 08:18 PM
  3. Biesse Rover 22
    By paul sharpe in forum Education - Teachers and Students Hangout
    Last Post: 09-22-2013, 09:35 PM
  4. Biesse Rover 24
    By lostinbiesse24 in forum Biesse
    Last Post: 12-06-2012, 07:17 AM
  5. Biesse Rover C
    By Dogfart in forum CNC Machining Centers
    Last Post: 06-07-2009, 05:17 PM
