588,268 active members*
11,432 visitors online*
    Apr 2006
    1016
    cnc indexer and lath combo
    I was wonder if any user have try to get the best of both worlds high speed cnc lathe and cnc index with router setup.... as see in video
    [ame="http://www.youtube.com/watch?v=Y2ZXzeScHx4&feature=related"]YouTube- Fluted Stair balsuter[/ame]
    [ame="http://www.youtube.com/watch?v=hASG9f6BLRU&feature=related"]YouTube- barley twist stair baluster[/ame]
    Im trying to figure out the best and simplest way
    to disengage the the 2 drive system that would required..( motor / stepper drive) with out ripping apart the head stock for change overs
    Dec 2008
    226
    I'm thinking big servo...
    Apr 2007
    90
    I am planning to start up the same after completing my Plasma build. We could share some ideas. What machine are you going to convert, or a scratch built one.
    Vishnu
    Apr 2006
    1016
    Quote Originally Posted by vishnu View Post
    Vishnu
    my thought are to design it in to my future 5x10 cnc router...
    the lathe would design to handle large work pcs like 10-12 inch columns 9-10 feet long. see the attach photo of legacy om5 design .... It would be simular idea but the cnc would be a build different.
    the servo idea is good, but i also need a indexer and gear box cus i would like to do corbells and carving on all asort of stuff....
    I was think of using a rotary plater gear head.. like picture attached but with a bigger stepper.... the shaft of the chuck would go threw the center of the bore hole. The bore hole of the indexed would be keyed in a way to
    engaged .. sliding on mounted track thus " engage or disengage the index via a locking cam arm..." notice the large bore hole in the gear head.
    This would allow the indexer to back off from the keyed shaft..
    to use high speed ac or servo motor. or Locked in place as need for slow indexing ... In index mode the index would be power just by the stepper motor
  1. Shoptask lath drive train replacement
    By kb7vms in forum Shopmaster/Shoptask
    Last Post: 09-21-2022, 02:49 PM
  2. Gifted Lath II / Worth Repairing ?
    By Jeff Davis in forum Taig Mills / Lathes
    Last Post: 11-23-2009, 09:18 PM
  3. a axis for lath option
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 06-21-2009, 12:44 AM
  4. combo ok
    By willheg in forum Stepper Motors / Drives
    Last Post: 03-25-2009, 07:46 AM
  5. EZ Path II Bridgeport Lath
    By enemylines in forum Uncategorised MetalWorking Machines
    Last Post: 04-18-2005, 06:09 PM
