588,477 active members*
5,605 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Chinese 3040 parallel port machine and MK3/4
Results 1 to 6 of 6
    Aug 2011
    999
    Can I expect the 26/25 pin connector of the MK3/4 board hook up with the DB25 of a cheap Chinese 30/40 (like this one) machine and work somewhat out of the box?
    These are intended for PC parallel port hookup with (I guess) an unauthorized Mach3 version.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Mar 2007
    2083
    Re: Chinese 3040 parallel port machine and MK3/4
    it will depend on the pin functions of the DB25 on the Chinese machine being the same as defined by the planetcnc motion controller
    Do you have any details of the pinout for the cnc machines DB24 connector ? or a link to the manual ?
    I expect you will find pins 2 to 7 will be correct for the 3 axis step and direction
    but you may find the mk3/4 enable out on pin 1 is wrong and needs to connect to another pin on the machine
    a modified printer cable could be a solution
    John
    if you do not have old computer, you can add USB connection. It is very easy
    Mar 2017
    1342
    Quote Originally Posted by automationtechinc View Post
    if you do not have old computer, you can add USB connection...
    This does not work with PlanetCNC software.
    Chinese 3040 parallel port pinout varies. On most boxes step and dir signals match. Simple solution is to break wire that does not match pinout.
    Another option is Mk3DRV which was designed as replacement for some:
    https://planet-cnc.com/replacing-chi...rv-controller/
    Aug 2011
    999
    Thanks, I am sure I can make it work somehow.
    The MK3DRV looks interesting. Is that a Trinamic Silent Step chip on there or what is the actual driver?
    Also, while the nominal voltage is supposed to be 24 V, what is the max. voltage rating?
    Mar 2017
    1342
    Driver used is DRV8825 which is robust and gives excellent performance. Voltage must be 24V.
  1. Replies: 3
    Last Post: 04-20-2019, 11:23 PM
  2. CNC 3040 Parallel port pinout
    By berlinmille in forum Chinese Machines
    Last Post: 09-15-2017, 01:53 PM
  3. FWIW: Controller/brain transplant for 3-axis Chinese CNC router to use parallel port
    By cnczane in forum Uncategorised WoodWorking Machines
    Last Post: 02-07-2017, 02:58 PM
  4. parallel port dead with pc-suggestions for purchasing usb/ethernet to parallel port?
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 08-19-2015, 11:32 AM
  5. arduino parallel port hack for Chinese 3040
    By RunForrestRun in forum USB, RS232, PARALLEL etc
    Last Post: 05-07-2015, 05:59 PM
