587,998 active members*
1,695 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > counter-clockwise vs clockwise arc problem
Results 1 to 15 of 15
    May 2009
    15
    If I run a simple program (example below) that cuts the same circle in clockwise and counterclockwise directions, the result is a shift on the y axis like the illustration I have drawn. I've been stumped on this problem for weeks and have narrowed it down to this simple problem. I've considered many possible causes but am beginning to think its the way the control interprets the code (Centroid M39). Has anyone encountered anything like this before?
    example G-Code:
    N100 G20
    N110 G0 G17 G40 G49 G80 G90
    N120 T1 M6
    N130 G0 G90 G54 X4.8943 Y2.5 S3000 M3
    N140 G43 H0 Z.25
    N150 Z.1
    N160 G1 Z-.25 F6.
    N170 G2 X.1057 R2.3943 F12.
    N180 X4.8943 R2.3943
    N190 G1 Z-.15 F6.
    N200 G0 Z.25
    N210 Z.1
    N220 G1 Z-.25
    N230 G3 X.1057 R2.3943 F12.
    N240 X4.8943 R2.3943
    N250 G1 Z-.15 F6.
    N260 G0 Z.25
    N270 M5
    N280 G91 G28 Z0.
    N290 G28 X0. Y0.
    N300 M30
    Resulting Shift:
    Jan 2008
    575
    I don't know where your offsets are or what diameter your tool is, but the first thing I would try is using "I" and "J" commands instead of "R". The best reason for this is you can complete an entire circle with one line of code.
    Hope that helps, I think it will, Robert
    May 2009
    15
    I've tried switching to I and J and had the same issue. The tool is 1/4" end mill, but the problem is the same with other tools. Oh, and I'm not using diameter offsets.
    Jun 2005
    1015
    i think your problem is backlash. how round is the hole to begin with? also cut it alot slower and see if it helps. i had a similar problem on my IH mill. apparently the bearing housing had loosened up and as long as i was going in one direction it was fine but as soon as i moved backwards the entire pattern would shift from the backlash. similar to what your seeing.
    May 2009
    15
    Quote Originally Posted by Runner4404spd View Post
    Backlash is one problem I've banged my head on the table about as well, but I don't think it would cause this. I may be wrong, but backlash will only shift the entire coordinates of the piece. So if you're cutting in to uncut metal the location will be slightly off from where you want it, but for any operation you perform it will be the off by the same amount. That being said, I haven't entirely ruled it out as the culprit.
    Jun 2005
    1015
    in this particular case i think it is backlash. i don't know how your approaching the hole, but if you come in with just an x move, you never preload the y screw, so before the move is made to make the circle the backlash has to be taken up. same goes for the reverse cut. i would adjust the gibs and check your ball screw and bearings on the wy axis.
    Jan 2008
    575
    With the blue pattern you are climb cutting, and with the red you are conventional milling. Could rigitity in the tool holder be the problem?
    May 2009
    15
    I'll look at it closer. The funny thing is I have more backlash on the x axis than the y axis so you'd think it would shift on the x axis as well, but only the y...
    Oct 2003
    263
    You only specify a Y coordinate one time. You're assuming that the tool is at Y2.5 at the start of each half-circle, but have you verified that? I'd try sticking Y2.5 in each circular move just as a test.
    Software For Metalworking
    http://closetolerancesoftware.com
    Mar 2009
    53
    I have had the same problem milling a rectangle. I had artifacts on the contour walls when milling with incremental depth. I do not know the deviation in your case but mine was severe (about 0.5mm). That's more then just backlash. In my case the four bolts that hold the housing of the lead-screw to the X-table were loose. Tightened them... problem solved.
    Jan 2007
    22
    Why do you have two G2 / G3 lines after each other, why not use I / J values?
    It could be how you're just specifying an X Coordinate for the G2/3 codes, if I'm using a G2/3 code like that I always put an X and Y in there. And how you're using a G2/3 as modal (not specifying G2/3 on the line after) looks dodgy to me. I always put the G2/3 infront of it.
    I'd write this as; (in metric)
    G15H--
    T-- (6 E/M)
    M6
    M1
    N1
    T-- (?)
    S--M3
    G0X25Y0
    G56H--Z25M8
    Z1
    G2I-25Z-6F--
    G2I-25
    G3I-25
    G0Z10
    G0Z100M9
    G30P2
    M2
    Jan 2004
    539
    This is the way surfcam spits it out. 2 inch circle... 1/4 endmill.. Circle center is X0.0 Y0.0.
    Gary
    G17 G40 G80 G90
    T1 M6
    S6112 M3
    G0 G90 G54 X0.875 Y0
    G43 Z1. H1 M8
    G0 Z0.1
    G1 Z0 F2.2
    G3 I-0.875 J0 F4.4
    G0 Z1.
    Z0.1
    G1 Z0 F2.2
    G2 I-0.875 J0 F4.4
    G0 Z1.
    G0 G49 G90 Z0 M9
    G28 G91 Y0 Z0
    M30
    May 2009
    15
    Quote Originally Posted by niggle View Post
    G15H--
    T-- (6 E/M)
    M6
    M1
    N1
    T-- (?)
    S--M3
    G0X25Y0
    G56H--Z25M8
    Z1
    G2I-25Z-6F--
    G2I-25
    G3I-25
    G0Z10
    G0Z100M9
    G30P2
    M2
    I think you are dead on. The code I posted was directly from Mastercam, and I went back to double check everything again and have FINALLY found the solution. To do this series of checks I just loaded a sharpie in a chuck and set the height so it barely made a mark, and the output gave me a very nice fine line. Okay, then I was just trying different code and wiping the mark after each iteration. Bottom line, I change the control parameter of Mastercam's Arc setting to ABSOLUTE vs. radial and the problem is gone (this gives output in I and J instead R). I now believe the problem is on Mastercam.... and in the future am only using ABSOLUTE. I hope this thread saves others this same headache.
  1. using a counter
    By gravy in forum Parametric Programing
    Last Post: 05-26-2012, 12:05 PM
  2. Testing 4 steppers,only turn clockwise
    By msg in forum Mach Software (ArtSoft software)
    Last Post: 01-26-2008, 09:10 AM
  3. Clockwise only, XYZ- and +?
    By lbrc in forum Mach Software (ArtSoft software)
    Last Post: 06-21-2007, 04:25 AM
  4. counter sensor problem on johnford vmc, need help
    By wiredude in forum CNC Machining Centers
    Last Post: 05-10-2007, 11:30 PM
  5. counter
    By cncsdr in forum Haas Mills
    Last Post: 11-08-2005, 02:56 PM
