588,495 active members*
4,827 visitors online*
Results 1 to 9 of 9
    Jul 2007
    32
    First time CNC build...
    Hello All,
    I am about to start building my first CNC machine today. I am going to build it out of MDF using some of the ideas that I have spotted on this site over the years.
    My backgound is in Electrical Engineering and metal work. I have decided to build my first router from MDF since I have most of the tools to work with it at home.
    I will try and get some pics up soon.
    Jul 2007
    32
    Here is the base that I built up on the weekend.
    I plan to just use threaded rod for the motion at this stage.
    16mm MDF with rebate joints.
    I will glue the joints later once its all fitting together well.
    Here is the complete base. I will mount linear rails and then start on the gantry.
    More Pics soon!
    Expecting some motors and drives this week. I have a controller PC and a case to house it all ready to go.
    Jan 2006
    106
    Looks nice, what type of motors are you getting?
    Jul 2007
    32
    Motors...
    I bought a few motors for the X and Y axis off a guy in Hong Kong for $50USD each.
    Here is a rough spec direct from the add.
    HIGH TORQUE CNC NEMA 23 Stepper Motor 28kg.cm
    HIGH SPEED HIGH TORQUE 28KG-CM (390oz-in)
    SHIFT DIA 8mm x 20mm LONG
    Max 3000rpm 1500rpm with half Torque
    DOUBLE SHIFT AVAILABE FOR ASK
    4A PER PHASE 6 LEADS
    SIZE : 57mm SQ X 118mm LONG
    Weight 1.6 KG
    IDEA FOR CNC MILL CONVERSION
    The drivers are coming from the same guy.
    I have a 750W PC power supply to use that is capable of 32A @ 12V
    I plan to use MACH3 on an old P4 that I will mount up in a hard plastic case.
    More pics tomorrow!
    Jul 2011
    39
    Can you sand me info , where are you buy that stepper , I need 4 pcs for my new CNC.
    Jul 2007
    32
    Motors and Drives have arrived.
    I have also built up a touch screen to use on an old 17inch LCD monitor. Cost $140 to get it working.
    Threw them on a test bench today and the drivers work well.
    I will take some pics and upload them asap.
    Mar 2009
    32
    Sweet Base !!!! I'm impressed !
    Looking forward to see your progresses...
    Oct 2008
    242
    have you thought about other power supplies? Those motors will need more than 12v.
    Jul 2007
    32
    Quote Originally Posted by Jack000 View Post
    I will start them off on a 12V system. The drives have inbuilt current limiting that I will set at around 4A.
    Eventually, I will go to a 72V system (as specified by motor/drive manufacturer) to increase rapid feed rates and torque.
    I have tested them on a 12V 3A bench top supply (motors unloaded of course) and the performance is acutally reasonable. They are not real good at high speed as you would expect.
    I will try and get some pics tomorrow if the weather is good here. Most of the basic electronics sorted. Just putting it all in a case at the moment.
  1. First time build in Toronto
    By Tupperwoo in forum CNC Wood Router Project Log
    Last Post: 06-19-2008, 08:42 PM
  2. First time CNC Router Table Build
    By InControl in forum DIY CNC Router Table Machines
    Last Post: 03-07-2008, 07:05 PM
  3. another first time build!
    By multiplex in forum CNC Wood Router Project Log
    Last Post: 11-29-2007, 04:19 AM
  4. DIY - Build CNC for the first time
    By XenC in forum Open Source CNC Machine Designs
    Last Post: 12-21-2006, 12:48 PM
  5. 3rd CNC ROUTER BUILD time to get serious.
    By Oldmanandhistoy in forum CNC Wood Router Project Log
    Last Post: 02-22-2006, 11:41 PM
