587,633 active members*
3,417 visitors online*
Results 1 to 3 of 3
    May 2011
    Pin 11 is Dead
    What I am running:
    EZRouter4x8 Table
    CanCNC MP3000E with their THC setup
    Hypotherm Powermax900
    Mach3
    Windows XP
    The problem I am having is that on the Table I/O card, I am unable to receive any input from the X-Home Connectors, on my printer cable it would be pin 11.
    Normally there would be an LED lit when the limit switch is connected, and off when pressed. I've swapped switches, and wires, but to no avail.
    On my Mach3 screen the sensor LED for pin 11 is also not lit. I don't believe the problem lies with the computer, but what tests should I run to help rectify this problem?
    Thanks in advance, and my apologies if this is in the wrong section,
    ---Douglas
    Oct 2004
    742
    Pin 11 on printer port logic is inverted.
    From memory:
    I am pretty certain that the logic input on pin 11 is inverted, as compared to the other inputs. Try changing the input to the opposite state, (voltage either +5V DC or to Power supply common to input via a 4.7K ohm resistor), and it should change in Mach 3.
    Jan 2011
    Quote Originally Posted by CJL5585 View Post
    Yes, pin 11 is inverted.
  1. A Dead X3
    By pntrbl in forum Benchtop Machines
    Last Post: 01-13-2011, 12:39 PM
  2. Dead CNC
    By UglyMachine in forum Shopmaster/Shoptask
    Last Post: 07-31-2010, 03:45 PM
  3. SOS dead OM-A
    By gabedrummin in forum Fanuc
    Last Post: 03-09-2010, 02:08 PM
  4. MV-40B ATC dead
    By steelhead1 in forum Mori Seiki Mills
    Last Post: 06-09-2009, 06:30 PM
  5. Fanuc 0 dead screen ... dead control?
    By Noss Machine in forum Fanuc
    Last Post: 01-24-2009, 04:03 PM
