587,201 active members*
2,842 visitors online*
Results 1 to 20 of 21
    Nov 2003
    108
    Leaving lines on material
    I have a mini mill self converted to CNC.
    Last night and I noticed that when cutting a largish flat surface with a .5 inch end mill I am leaving lines on the work. The lines are parallel to the X axis indicating the Y axis is out of tram.
    The lines are deeper towards me (if that makes sense) and are maybe 1-2 thou deep. They are noticeable and can be felt with the ball of your finger.
    Has anyone experienced this?
    Is there are way to correct this?
    phil
    Mar 2006
    93
    hi beerfizz
    it has been my experience when this happens your z axis is out of plumb and you need to trammel the head
    Nov 2003
    108
    Thanks for the response Dar,
    The head has an adjustment from side to side, if you were standing in front of the mill. Adjusting this would take out any lines which are parallel to the Y axis.
    The lines I have are parallel to the X axis, and in my case seems to indicate that the head is leaning forward.
    I am looking for a way to correct this?
    Ideas?
    Mar 2006
    93
    with a bp you can adjust the head both ways. but i have a bp2 so if i have that problem i have to shim tha head BIG JOB. you are going to have to do the same good luck
    Dar
    Sep 2006
    881
    I'm not sure which machine it is that you have, but i was just thinking, if its built like mine, the griz x3, there is the potential for slack in the z axis ways, so, in my mind, if theres slack in the z you might tighten the jibs a little and see if that changes anything...
    if the head is pretty solid with the column, then it sounds like the column is not plumb..
    .002" over .500" is an angle of .23deg. so its not much.. way smaller than anything than i can measure.
    ok, so i'm going to ask this next question, cause its something that poped in my head, and i havent had my coffee yet... is it possible for the work peice to not be flat down against the table, could that cause this angle gouging?
    Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
    Nov 2003
    108
    Hi Project,
    Thanks for the reply.
    I have my mill in pieces at the moment, so I can't test much, perhaps in a few hours.
    I have a X2 Mini Mill, the X3's baby brother. Yes, there is the potential for some slop in the Z especially if the Gibs are not tightened correctly. When I have everything back together I think I will tighten the gibs, starting at the top and work my way down. If there is an issue, perhaps that will pull the top in first and cause the head to be straight instead of leaning forward. This all seems to be somewhat of an Art.
    Best
    Phil
    Jul 2004
    218
    How about adding this kit?
    http://littlemachineshop.com/product...gory=879658189
    I have the same problem with my X2.
    Nov 2003
    108
    Hi Dang,
    Thanks for the response.
    Have you tried adding the Air Spring yet? That could be a good idea.
    As I mentioned in an earlier post, I thought I would try tightening the Gibs from the top, to see if that would pull the head back a little. Interestingly it worked some, but not entirely, I think I reduced the line by half or maybe more. Its almost not noticeable, but you can feel a slight raise.
    When I compare it to the X Tramming on the head, I have that set to less than a thou over about 10 inches. The half inch end mill leaves a perfectly flat surface in that direction.
    So, there is still a little room for improvement. I would hate to go through the process of taking off the head shimming, trying and perhaps having to shim again.
    The Air Spring might be a good idea?
    Also, its clearly a good idea to tighten the Z gibs often. (for me, from the top down, if that makes a difference at all).
    Anyone any other ideas?
    Phil
    Edit: I should add, that I currently have no additional support on the Z other than the servo and ball screw.
    Feb 2007
    1041
    Hi Phil
    I'm experiencing this right now as we speak with my X1, little brother to the X2.
    I've spent almost 10 hours now trying to figure out my Z axis issues, but only got a little bit of improvement. I can't go all the way up without the motors stalling, not unless I loosen the gib screws a little more. The problems is when I loosen them too much the head starts to make a funny deep sloppy vibrating sound when jogging down and while jogging down if I push up on the head the dovetail comes off the track. It's a PIA to get them perfect and having figure it out yet.
    Now I had an idea with adding a longer gib plate to the Z head. This would extend a little more on the top and bottom, allowing maybe a little more support, but haven't tested it yet.
    Here's the part and if you look closely inside the ring, you'll see a layered looking surface (not the way it is suppose to look at all).
    I wish they made something like that compression spring for the X1, I feel like I own the red headed step child. I'm most likely going to make my own to hold me over until I decide on my new mill (looking into the Tormach).
    Feb 2007
    31
    Phil,
    I had this on my X2, also. I just fixed it, yesterday. Mine was off by about 5 thou from the front of the table to the back. I loosened the three screws that hold the column pivot-plate to the base, tilted the the column back and put a shim under the pivot-plate. I used a 0.002" feeler gauge for a shim and got lucky the first time. Now, it's under half a thou, front-to-back.
    - Don
    Feb 2007
    1041
    "I used a 0.002" feeler gauge for a shim and got lucky the first time."
    Do you have any pictures of what you used ? Kind of new to machines and tooling.
    Yea I think mine is somewhere around .010 or so. I've taken apart my machine and fixed everything but the head. (chair)
    I'm going to take it apart from the base tonight and hope to figure out the problem!
    Nov 2003
    108
    Quote Originally Posted by dleroi View Post
    Phil,
    - Don
    Fantastic!!!! Thanks for the idea Don...
    I'll see if I can take a shot at that tonight.
    Phil
    Nov 2003
    108
    Quote Originally Posted by twocik View Post
    Hi Phil
    Hi twocik,
    This particular issue sounds like the "mill head" and the "column mount for the ball screw" are out of alignment. This is evidenced by the fact that as the head gets closer to the top, it gets tighter and harder to move.
    Perhaps you can try something like this. Move the head as high as possible either under power or manually. Then loosen the bolts which hold the mount attached to the column (the mount that holds the ball screw -- I'm assuming that your system is designed like this ) Then, if there is enough clearance in the bolt holes, wiggle the mount around so the head moves more freely than before. If there is not enough clearance in the holes can you drill them out a bit?
    Hope this helps
    Phil
    Jul 2005
    442
    Hi Phil
    You can use a gas spring like 4138T56 from McMaster to build your own.
    Also, check the factory gib - they are normally junk and should be replaced.
    Aaron
    Feb 2007
    1041
    Thank you, had know idea what a shim was. It's a little different on my mill (X1), I used a machinist square to level mine column.
    "Also, check the factory gib - they are normally junk and should be replaced."
    I took the machine apart last night for the second time and notice that there must be some sort of bend, bind in my column ways. Make a long story short it was the factory gib plate, along with a few chips stuck inbetween the gib plate and way. I can now move up & down with no problems, well not all the way up, yet. I need to look into a stronger stepper or some sort counter weight system.
    Phil not sure if you got your mill up and running again, but if it helps try laying the column (you'll need to unscrew it from the base, not the whole mill) on it's back side for adjusting.
    Nov 2003
    108
    Quote Originally Posted by pastera View Post
    Aaron
    Aaron,
    can you post a link to where we can obtain new quality gibs?
    Nov 2003
    108
    I sure do. Is that what it calculates out as?
    Feb 2007
    31
    Quote Originally Posted by BeerFizz View Post
    That should be pretty close, but it may take some trial and error because it depends on how far back you place the shim(s) how much you torque the bolts, etc.
    - Don
  1. help with pockets leaving islands
    By touser in forum Mastercam
    Last Post: 08-14-2007, 11:30 PM
  2. Leaving tabs on small parts
    By thunterman in forum BobCad-Cam
    Last Post: 12-21-2006, 05:17 PM
  3. Leaving tabs for model parts
    By Ninjak2k in forum SheetCam
    Last Post: 03-30-2005, 09:04 AM
  4. Leaving your steppers on.
    By wjbzone in forum DIY CNC Router Table Machines
    Last Post: 08-13-2003, 01:30 AM
