Originally Posted by
Bobbyr70
Ok, I want to build my own cnc plasma and router table.
I trust you mean one of each and not a combined one?
Bobbyr70
Another question is around calibration and gearing. I was looking at using gear rack and pinions as an option for driving the carriages. Is there a desired calculation for ratios that are more desireable for the drives? or are they just aobut infinitely adjustable?
What are the pros and cons of gear and pinion mechanical drives versus acme screws or ball screws?
Look at some of the free servo/stepper sizing programs like Kollmorgen etc , almost every servo/stepper motor manuf. has one.
Usually the type of drive is dictated by the size of the table.
Gearing allows the economical sizing of motor & drive unit, but the top speed of the motor and the required max feed rate generally governs the max. gearing ratio.
Al.
Albert E.
