588,655 active members*
5,621 visitors online*
Thread: Coolant
Results 1 to 6 of 6
    Feb 2011
    308
    Exclamation Coolant
    Guys I know that the questions was asked so many times but what is the best coolant to use in a garage? I do not want the coolant to irritate my eyes and kill my lungs.
    Jun 2007
    93
    Quote Originally Posted by Pysiek View Post
    Its not so much the coolant, as it is how you apply it. "Some" Mist systems have a tendency to "Fog" and put the coolant in the air which can cause the issues you mentioned. Mist systems like the Fog buster or the Noga Mini-Cool are supposed to be pretty good and not "Fog" up the shop. Or you could just use a traditional flood coolant, which would not "Fog" but you would need some method of collecting, filter out chips, and re-pumping it to the work piece. No easy answer sorry.
    I guess WD40 and a compressor is a pretty good temporary solution though. But gets to be a PITA real quick.
    SFL
    Feb 2011
    308
    I'm gonna use the "flood" system. Right now I'm designing a case in which I will be able to use the coolant.
    Also I already have purchased that kit: LMS coolant kit.
    Feb 2006
    7063
    KoolMist 77 is about the most benign stuff there is. No irritation, no odor, no mold/mildew. And it's pretty cheap - about $30/gallon, which dilutes to 32 gallons.
    That said, for a benchtop mill, I would use mist. Flood is very messy, and simply not necessary on such small machines. And, you'll go through a LOT more coolant with flood. I worked my way through a single gallon of KoolMist over 3 years with mist coolant. After switching to flood, I go through a gallon a month.
    Regards,
    Ray L.
    Dec 2010
    1230
    I use kool mist and learned to mix it about 1:5 with water to prevent rust unger my vises. sed to get surface rust unless I pulled my vise every few nights, but two nights ago I pulled both vises for a fixture and not a hint of rust even though they have been on for 2 weeks and I've used a 1/4 gallon of coolant in that time (doing short production runs with a LOT of drilled holes. I crank the mist pretty high even drilling and slotting. 77 is cheap.
    Feb 2011
    308
    Guys thanks for the info. I went with Syn-Kool. I have looked over the hoss's project where he build a flood coolant enclosure. I think I might build similar one.
    Did you guys make your own coolant enclosures?
  1. X4 coolant
    By GTC in forum Syil Products
    Last Post: 08-07-2010, 02:05 PM
  2. Coolant Tip
    By ntcnc in forum Uncategorised MetalWorking Machines
    Last Post: 07-22-2010, 01:31 PM
  3. Looking for a better coolant?
    By shawn in forum MetalWork Discussion
    Last Post: 06-29-2009, 04:13 PM
  4. Coolant...Which and why?
    By ajl6549 in forum MetalWork Discussion
    Last Post: 12-08-2008, 03:02 PM
  5. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
