588,461 active members*
5,315 visitors online*
IndustryArena Forum > CAM Software > OneCNC > Z Level Finish
Results 1 to 6 of 6
    214
    Z Level Finish
    Note the following picture. I am using z-level finish to do this. When I select only the blue layer to machine, leaving the amber pieces unselected, the program still machines the unselected portion of the part. Is there any way to only machine the selected portion.
    Ken
    214
    Here is a picture of the toolpath.
    332
    Put them on another layer and blank them? Fill any holes as neccesary?
    4826
    Mortek,
    Keithorr is basically correct. What OneCNC is doing is avoiding machining through the yellow pins, which is exactly what you would expect it to do, with its surface detection logic. When they are visible, then they are considered.
    If the pins are not actually integral to this part, then blank them, as there is no danger of running into anything, because, in fact, they do not exist when the blue part is being machined.
    That is my take on it, just by looking at what seems logical, but I've been fooled before by your models
    First you get good, then you get fast. Then grouchiness sets in.
    214
    I always get a little confused. Want them there because they exist after the roughing operation. They contain the clamping bolts. I thought they needed to be there to avoid being run into. You're right, if they aren't there then the softeware doesn't consider them. I just had to remember to set my Z clearance high enough to clear the bolts.
    Ken
    927
    Edit: Sorry Ken posted before me.
    Let me Guess.
    Those "pins" are what you are using to hold the part to a fixture?
    You can use Planar Finish to selectively cut the Blue stuff, but not z-level finish.
    You may be able to set up some boundaries to "miss" the pin areas.
  1. Mill finish on Aluminium sheet.
    By ynneb in forum MetalWork Discussion
    Last Post: 06-22-2008, 11:52 AM
  2. 3 Flute High Helix Endmill Problem
    By Joe_CNC in forum MetalWork Discussion
    Last Post: 07-20-2005, 01:07 AM
  3. Homemade PCB 'fit and finish'
    By shadow in forum CNC Machine Related Electronics
    Last Post: 02-06-2005, 01:01 AM
  4. Aluminum Matte Finish
    By Tazzer in forum MetalWork Discussion
    Last Post: 04-13-2004, 04:31 PM
  5. Cutting bit questions
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2004, 10:12 PM
