hello!
i need help PUMA 6J Machine Parameter Power Off after Clear
controller Fanuc 0-T Series
Machine made in 1994
x,z Axis Servo motor α3/3000
Spindle Servo motor α6/speed unknown
All Clear Parameter & DGNOS Data
Help me Please.
hello!
Help me Please.
Hi maintenance-man I have a daewoo puma 8hc with the same problem as yours, it lost the parameters and I am still looking for the appropriate parameters since on the internet I have been able to get some of the daewoo puma but not the exact mine that is if you want I can share you I have the case that my machine has managed to make the hydraulic and lubricant work but not the axes and the spindle is the machine with an interlock of not ready and two relays of LEDs in the cabin lit hovl and movl, you can send me photos of your puma 6J to see how similar it is to mine? If it is similar to mine, do you have the user manual?
If your 8HC has a 15T control, here is a generic set. (it is likely that it will not fix all issues as many parameters are serial number specific)
Doosan Service Technician
[email protected] O:973-618-2461 M:973-803-9479
There is a set of parameters of how the machine left Korea, located in the pocket welded into the inside of the electrical cabinet door,
Here is a generic set. It is likely that they will not completely recover the machine, as they are serial number specific.
To anyone who has a machine YOU CAN MAKE YOUR OWN BACKUP at ANYTIME YOU WANT!
You can backup the full readable files, as well as a binary copy of SRAM.
This backup can be done in about a minute.
If there is a functioning machine on your shop floor...GO...DO A BACKUP...Today.
Then you won't have these issues.
