588,216 active members*
3,993 visitors online*
Results 1 to 8 of 8
    Sep 2011
    474
    Which updates to install?
    Im just transitioning to PP and have heard that there have been some issues regarding some of the updates. Should I update "all the way" to the most current iteration or stop short at a certain update?
    Apr 2013
    1788
    Re: Which updates to install?
    Each update has its own selection of issues. That said, I've had rather few problems although I've used most versions starting with the Beta and am now happily making parts with 1.9.3. It is probably prudent to let each new version "age" for a week or two prior to installation!
    Feb 2009
    328
    Ive installed the latest with so far no issues.
    Sep 2011
    474
    Is this just done with a thumb drive or can I plug an Ethernet cable directly into the controller?
    Apr 2013
    1788
    Download the desired version from Tormach (updates are about 12MB), copy the file to a USB drive, insert USB drive in an available slot. In PP click "Update" on the Settings screen and follow the prompts. The identification of the version currently installed is displayed near the bottom right corner of the PP screens. I believe that the latest is 1.9.3. At least that is what I'm running.
    It may be possible to update over Ethernet but that is not the recommended procedure and I have no idea how to do it.
    Sep 2011
    474
    Quote Originally Posted by kstrauss View Post
    Thank ya much!
    Sep 2013
    32
    Tormach states that you can skip updates and jump to the most current. I am also using 1.9.3 and I have no issues with axis control paths. I am currently running a 10K line program and the Z axis DTG does not update unless I single step. Then when the machine pauses the Z axis DTG does update. The X & Y are fine not sure why the Z would have this behavior as it is updated way less frequently than X or Y.
    Jun 2006
    340
    Little_chips,
    Is your controller an off-the-shelf controller from Tormach or have you used a different computer and installed PP?
    Bevin
  1. Updates
    By Gregore in forum MadCAM
    Last Post: 03-18-2014, 05:42 AM
  2. Un-install & re-install changes Mach3
    By Beefy in forum Mach Software (ArtSoft software)
    Last Post: 08-01-2012, 09:01 AM
  3. X4 updates????
    By WingNutz in forum Mastercam
    Last Post: 10-27-2009, 06:52 PM
  4. Updates on v4
    By robinsoncr in forum MadCAM
    Last Post: 03-03-2007, 06:04 PM
  5. 4.0 updates ?
    By bobleecnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-05-2004, 01:48 AM
