588,533 active members*
8,820 visitors online*
Results 1 to 5 of 5
    Oct 2011
    303 stainless warping
    Started out surfacing 303 stainless plenty of cutting fluids ,little to no heat generated, simple shape just a radius around outer edge then a simple contour out the shape .After done machining part has large bow or warping, can anyone make a suggestion about what might be done to stop the warping Thanks
    Jul 2005
    12177
    If you are cutting this out of plate or flat bar it is difficult to avoid warping. Stainless steel work hardens during the rolling process and there are a lot of stresses in the finished plate or bar. If you only machine on one side the stresses are relaxed unevenly and warping occurs. If you left the radius off you might find the warping is less.
    Probably the only fix is to normalize or anneal the material before machining. This does alter the corrosion resistance a bit and may make it more difficult to machine. Annealed stainless is soft and behaves 'gummy' when being machined.
    Oct 2011
    Thanks, Geof. This answers the question perfectly. Now I'm going to add to a growing pile of brass chips!
    May 2004
    4519
    Another way to handle this (still takes more time and money) is to start with about 0.125 oversize stock and rough machine it leaving about 0.010-0.015 per side for finish. Flip the part and repeat. Then flip the part for finish. Then repeat again.
    Oct 2011
    Thanks man, that is what I would normally do,just got caught up in the rush mode ,thanks agin
  1. Nylon Sheet Warping
    By Mattyvdv in forum MetalWork Discussion
    Last Post: 06-30-2011, 04:24 AM
  2. Any way to limit warping on thin material ???
    By flyinwilly in forum Waterjet General Topics
    Last Post: 03-11-2011, 05:02 PM
  3. Wood warping after milling
    By SteveS in forum WoodWorking Topics
    Last Post: 02-23-2011, 04:53 AM
  4. 304 sst warping
    By jim@edmik in forum MetalWork Discussion
    Last Post: 12-22-2008, 03:13 AM
  5. Help with warping material
    By snaggletto in forum MetalWork Discussion
    Last Post: 04-09-2005, 04:22 AM
