588,443 active members*
5,083 visitors online*
IndustryArena Forum > CAD Software > Solidworks > stp file not opening
Results 1 to 9 of 9
    Jun 2008
    152
    My friend just bought SW 2013 and I'm trying to learn it but cannot get this file to open. I have a stp. file and dxf. file as well as a stl. file. The stl file will open but doesn't allow me to edit it. The stp file gives me an error about missing data. Can someone help me? Thanks
    Attached Files Attached Files
    Jun 2007
    3735
    Try export as ACIS.
    Jan 2012
    59
    the step file has a surface error can you get the file out as a .xb or .xt
    thats more up to date solid data
    the .stl opens fine what are we making here snow boards?
    Jun 2008
    562
    Quote Originally Posted by a1diesinker View Post
    I was only able to open the stl file as a graphics file only. Unable to get anything but a pretty picture from that.
    The other files had critical surface areas and would not open.
    As said a x_t or xmt, x_b or xmb would probably work better. Even give Iges a shot.
    If that doesn't work try SOL
    Mike
    Jun 2008
    152
    file from boardcad
    Thanks Guy's, the files are generated from a free surfboard design program called Boardcad 2.1.. The only files it exports are nurbs to step., dxf., and stl..
    I've seen where people are opening in rhino but I don't have access to that. Is there any way to clean up the file and get usable data? When I look at the stl file in featurecam it only consist of a skin surface in a top and bottom section. I would like to get a solid part that I can split into to shells. Any help is much appreciated. Thanks, Forrest
    Jun 2008
    562
    Quote Originally Posted by Forrest C View Post
    Well I used the dxf file and imported to Solidworks. Then exported to a xmb file and reimported. Was able to get a file with many surfaces and gaps. I don't know if its useable for you or not. You can check with the Boardcad people to see if they can increase the resolution of their output file and "maybe" it will knit up. I'm not real confident though.
    Good luck
    Mike
    Mar 2011
    Smile
    Forrest,
    I cleaned one of the stp file saved as parasolid file.
    I don't know which version of SW you got.
    Anyway open this file and you can do an Import diagnostics and select Attempt to Heel all.
    Hope this helps
    Any progress on this thread? Just looks interesting.
    Thanks,
    Pat H.
    Jan 2007
    1795
    last nigth i was curious what can be done with..
    the original file had some hole.. im not sure how it can occured..
    heres a 3ds format, the smallest of formats.. stl using the most bytes also stl alway only triangles..
    many program can read only closed, called watertigth stl
    in the file is a fully closed body, and two shell..
    best regrad
    viktor
    program seen is accutrans for converting.. to different formats..
    MicroMouse - Home
    model made with subdivision modeler..
  1. New to bobcad v22 help opening file?
    By Coolster in forum BobCad-Cam
    Last Post: 07-02-2018, 09:01 AM
  2. opening mcx2 file
    By vertix19 in forum Solidworks
    Last Post: 02-16-2011, 03:35 AM
  3. Opening a .dwg file ??
    By AirChunk in forum BobCad-Cam
    Last Post: 09-22-2010, 02:35 AM
  4. opening a mastercam x file on v9
    By drewmeister in forum Mastercam
    Last Post: 12-16-2008, 12:54 AM
  5. Opening CDR file extension.
    By terry32506 in forum Uncategorised CAM Discussion
    Last Post: 03-02-2008, 05:53 PM
