588,263 active members*
5,091 visitors online*
Page 1 of 3 123
Results 1 to 20 of 46
    Jan 2006
    387
    Mach 3 Mill feed rates
    I'm trying to run Mach 3 Mill in a simulation, and the execution times for simple programs are just plain silly- an hour and 30-plus minutes for cutting a 3-inch by 1.5 inch hole in half-inch plywood?
    I've got do be doing something wrong. But I dunno what.
    I've tuned the motors to match the 116-ounce motors on the machine, I've tred adjusting the feed rates, and they just keep reverting back to 1. Must be the drawing I imported, but it's a simple rectangle, how tough could it be?
    I've downloaded the latest pdf helpfle for Mach 3 I could find. Haven't looked at it yet but I'm headed there now. I just thought I'd ask here to see if anyone had any ideas.
    35538
    Is there an F1 in the g-code?
    35538
    Could you post the g-code for that? Even with the feedrate at 1ipm, it should only take about 10 minutes.
    35538
    If you're importing a .dxf, set the speed in the import dialog box, use the layer button.
    Jan 2006
    387
    Yes, there are two concurrent F1's in the first section of code alone, and several more down the line.
    Here's the first basic section:
    G90G80G49
    G0 Z1.0000
    G90.1
    S1000
    G0 Z1.0000
    G0 X-97.0000 Y29.8333
    M3
    F1.000G1 Z0.0000
    F1.000G1 X-97.0000 Y42.8333
    G1 X-97.0000 Y43.5000
    G1 X-97.0000 Y44.1667
    G1 X-97.0000 Y44.8333
    G1 X-96.8333 Y45.6667
    G1 X-96.6667 Y46.3333
    G1 X-96.5000 Y47.0000
    G1 X-96.1667 Y47.5000
    G1 X-96.0000 Y48.1667
    G1 X-95.6667 Y48.8333
    You can see I'm a total newb and am relying enirely on the conferters at this point because I won'tknow what I'm looking at until I learn a bit about the G-Code itself.
    I don't even think I know enough to ask intelligent questions. Here's a question: If I change that F1 to something like F40, will that change the feedrate to 40?
    35538
    Quote Originally Posted by Ed_R
    Sure will!
    Jan 2006
    387
    Did that, I lost the motor tuning though so it's still taking
    its own sweet time- over 30 minutes to cut about 9 inches!
    Appreciate the help, by the way. The toolpath that this converter is using isn't all that efficient, I can see some changes to make already
    Jan 2006
    387
    Ok, I am confused. No matter what I do, even if I set the motor tuning to outrageous settings, my speed is ridiculously slow- something under an inch a minute, even with my feedrate set to 100. Any more sugestions?
    Jan 2006
    387
    What might be happening is that the scale of the drawing might be way off, or the scale of the drawing and the scale of the Mach3 software are not the same. I need to find out where the machine limits are so I can see if the drawing needs to be scaled.
    Jun 2003
    2103
    Ed when you are in config and tuning your motors, have you been saving the axis after making all the adjustments?
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Jan 2006
    387
    Quote Originally Posted by turmite
    Mike
    Yes, I have, but I',m not certain my settings are correct to begin with. All my axes are set identically, and here's a screenshot of the settings:
    These look like they are in the ballpark for the 116 ounce motors on my machine, so I'm looking at the drawing scale, because my feedrate is at 100, and it's taking way too long to even plunge .
    Aug 2005
    157
    I'm still learning Mach as well, but I think you missed what Gerry said:
    "If you're importing a .dxf, set the speed in the import dialog box, use the layer button.
    __________________
    Gerry"
    There you can set the feed rates for plunge and direction, I think they default to 1 untill you change them, then they stay at what you set for the futer.
    The motor tunning should not matter to generate the G-code, it will generate what ever you tell it to, if your machine can't run that fast, well.....
    Aug 2005
    157
    By the way, is Mach set to run in metric? If so then you are moving at only 1mm per min!
    Feb 2005
    32
    Hello ED r
    Try to set the "step pulse" from 1us to 5us.
    Hope that helps.
    Per.
    Jan 2006
    387
    I did reset the speed in the layers to 100, along with the spindle speed and the tool number. I defined Tool 1 as havinga .25 diameter and 1 inch cutting length.
    I didn't change Mach from mm to Inch. I'l'l go do that, if it's not too difficult. Any tips?
    35538
    If it's setup in mm, and you switch it to inches, you have to re-tune the motors.
    What does the Feedrate DRO say while it's cutting?
    Jan 2006
    387
    The motors are definitely set up in inches, as are the screws.
    The DRO is reporting variable values, from around 45.5 to over 145. With a unit per rev of .02.
    35538
    If the feedrate DRO says 45, then it's cutting at 45ipm. Are your steps/unit setup correctly? What is the pitch of your screws? Microstepping?
    Jan 2006
    387
    Remember, this is all simulated, I don't have a machine connected yet.
    That 45 is the LOW end of the speed, but it's still taking 15 minutes to cut 9 inches.
    I don't know if I'm microstepping or not, and I don't know where to set the pitch of the screws.
    35538
    Does the simulation take 15 minutes? Or does Mach3 say it will take 15 minutes?
    The pitch and any microstepping is figured into the steps per inch, where you have 3600.
    Should be 200 x turns per inch x microstepping amount (8 for 1/8 step, for example)
Page 1 of 3 123
