Does anyone have a Dynatorch post for Fusion 360?
I'm sure I can modify a post to use G23/G25 myself but I figured I'd ask before I re-invented the wheel.![]()
I modified the WinCNC Plasma post processor for my Dynatorch. It was fairly easy. Now I need to work on my tool library so I can get the correct feeds, speeds, and kerf width. Over all the code produced looks very clean.
Not sure if the Dynatorch can do cutter comp (G41/G42) so I switched the compensation type to "In computer" on the dialog tab.
Just FYI, DT does support G41/G42.
We appreciate that you shared
www.integratedmechanical.ca
I just noticed that Autodesk now has a post processor for the dynatorch. I made the switch yesterday and it has been working as expected.
https://cam.autodesk.com/posts/downl...torch%20plasma
