588,703 active members*
7,745 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Dust Collection for Wood Machining - 1st Gen VF3
    Feb 2012
    52
    I have access to a 1994 VF3, and I am going to be machining electric guitar bodies and necks. Does anyone know of a commercially available dust collection boot for the spindle - like what you see on the CNC routers? As an example, I am thinking of something like this:
    https://www.workshopaddict.com/tools...p_close_up.jpg
    Your help is appreciated.
    Feb 2012
    115
    Re: Dust Collection for Wood Machining - 1st Gen VF3
    If you have the standard air/oil lubricated spindle you aren't going to like the oil mist that comes out of the spindle nose.
    I think that type of collection will be frustrating, especially because of the tool changer. I'd sooner say go with a air blast type situation, and let it collect below.
    Feb 2012
    52
    I'll be changing all tools manually (there aren't many, and the cycles are long). I'm trying to avoid causing a ton of work shop-vac'ing the machine of saw dust, since the machine is primarily a metal cutting machine and maintains a full coolant tank.
    Mar 2014
    133
    Best of my knowledge no, other than get a small extraction system and route the house on the side of the head sheet metal stopping close to the spindle. If you use air blast it can't be more than the vacuum system.
  1. Replies: 35
    Last Post: 03-13-2018, 03:41 AM
  2. Dust collection : Dust deputy, clearvue min etc. - need some help
    By FoxCNC1 in forum Uncategorised WoodWorking Machines
    Last Post: 03-08-2015, 02:26 PM
  3. Sensing dust level in dust collection bin
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 04-07-2013, 10:26 PM
  4. Replies: 1
    Last Post: 05-16-2012, 07:20 AM
  5. Dust Collection
    By bkboggy in forum WoodWorking Topics
    Last Post: 02-23-2012, 02:07 PM
