587,137 active members*
3,433 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Any experience with this servos?
Results 1 to 2 of 2
    Jan 2021
    4
    TS Series 3 Axis 12.0Nm(1699.68oz.in) Nema 34 Closed Loop Stepper Kit w/ Power Supply
    Nov 2013
    4477
    Re: Any experience with this servos?
    that is NOT a servo....it is a closed loop stepper and the manufacturer would have you believe its as good as a servo...its not.
    All steppers lose torque the faster they go....thats plain physics and a closed loop stepper suffers the same thing.
    If your stepper misses a step, it must be slightly overloaded at that speed, otherwise it would not have missed a step right? The drive
    will insert an extra step to catch up, but guess what the extra step is just as likely to be missed as a regular step.
    Closed loop steppers can and will fault out if too many steps are lost rather than continue and wreck the part. They can also accurately interpolate
    between steps and therefore offer greater resolution than an open loop stepper. These are advantages but you pay a premium for them.
    What a closed loop stepper does not do is:
    1) Go faster
    2) Have more power
    3) Have higher overload capacity.
    These 12Nm steppers are a poor choice, many get sucked into buying them because of all that torque...right? But they run out of steam at about 500rpm.
    There are much better steppers with only 3-5Nm but will still have useful torque at 1000 rpm plus.
    Steppers have no overload capacity, when they get to their maximum at whatever speed, any extra load and they stall, no ifs or buts, they just stall. A servo, either a
    brushed DC servo, a brushless DC servo or an AC servo will have three to four times its rated torque as a temporary overload. When a servo gets overloaded it jut 'digs in' and
    delivers more power.
    In short a well chosen LOW INDUCTANCE open loop stepper and the HIGHEST VOLTAGE DRIVE/SUPPLY will match any closed loop stepper.
    If you really want closed loop performance then get genuine AC servos like Delta B2 series or DMM.
    Craig
  1. Are Chinese servos a gamble? Servos vs Leadshine closed loop
    By j3dprints in forum Servo Motors / Drives
    Last Post: 01-05-2018, 07:09 AM
  2. Replies: 0
    Last Post: 09-15-2016, 10:54 AM
  3. Propriatary AC servos into universal AC servos with an encoder swap?
    By SwampDonkey in forum Servo Motors / Drives
    Last Post: 05-10-2013, 07:22 PM
  4. Has anyone had experience with.....
    By spunky1974 in forum Linear and Rotary Motion
    Last Post: 07-09-2007, 06:56 PM
