587,818 active members*
3,239 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD or Spindle problems
Page 1 of 4 123
Results 1 to 20 of 79
    May 2019
    41
    I am new to the site and also new VFDs. I built a copy router which is manually operated. My son who works at a place with many CNC routers and mills, insisted that I use a VFD and spindle motor instead of a trim router. I agreed and purchased a 1.5kw spindle and Chinese VFD from Ebay. After doing all the modifications to my design, I got everything together and it ran great. Until now. I started to get The E.ol error and the motor would stop. It was intermittent at first and I blamed the extension cord that I started using. I eliminated the extension cord and it seemed ok. Note that this is a 220V unit. I checked out the cord and it seems fine. Now I am getting the E.ol and E.oc errors. I come to this site and decided to to check my programming. That is when I really screwed things up. I finally got things to run (statically) but here is the max output. I haven’t tried to use the router, just ran it in place for a few minutes. I am going to check my line voltage next because it seems high with my cheap HF multimeter (~260-270V at the outlet). This may be the multimeter. I have used this router occasionally for almost a year with no problems to speak of. The seller on ebay gave me special parameters, which I have seemed to misplace.
    May 2019
    41
    Re: VFD or Spindle problems
    Please note that before I fooled with the programming I had total control from 0-24K RPM.
    Also, The error message seemed to have a 5 or S as the the last digit.
    15362
    Quote Originally Posted by tarawa View Post
    I advise not to run it until you have it programed and the wiring checked it looks more than one problem that you have how have you wired the input power post a photo
    Mactec54
    May 2019
    41
    The wiring is correct as I have been running without a problem for about a year. I started getting the overload error intermittently when using the duplicator. I first thought that I was taking too late of cuts. As I said this is manually operated soI started taking shallower cuts. It then started giving me the overload error while free running and not cutting. I have never had the spindle get hot and when it did error I was able to just restart it and it would run for a while before stopping.I should not have tried to go through the programming. I have to get my voltage checked using another meter to see if my meter is accurate. If it is, my line voltage is too high.
    15362
    It has nothing to do with how long it has been running, it can still be wired incorrect and still run it can take that long for a VFD or spindle to say enough of this I'm not going to work anymore you won't be the first one or the last for this to happen
    Your line voltage will be fine no matter what it is, as long as the voltage is not to low, you can only check the input voltage, do not try to check the output voltage with a regular meter or you can damage the IBGT's and your meter
    What Parameters do you have set or changed ???
    Mactec54
    May 2019
    41
    Here are the various errors that randomly shut me down.
    Attached Thumbnails Attached Thumbnails E0A6630C-6BFA-49E4-8F27-C49B643CCF83.jpeg   F468011C-76AB-418C-93BD-0C70D2707AB2.jpeg   EBB59BBE-5119-4DFE-9CE4-67C32A6626B1.jpeg
    May 2019
    41
    Sorry double post
    May 2019
    41
    After setting PD013 to 8 (factory default), I set the following to my original settings as supplied by the seller.
    PD002 =1
    PD005, 004, 003 = 400
    PD072 = 400
    PD070 = 1
    PD144 = 3000
    I checked wiring and it is correct for 220v. Everything is wired with #16 gauge wire.
    VFD controls function correctly now but motor still faults.
    May 2019
    41
    Here are my original instructions. Glade I saved the email.
    Attached Thumbnails Attached Thumbnails 7C9D5D37-5AE4-49F7-A4E7-0D2036D228CA.jpg
    15362
    PD002 =1
    PD072 = 400
    PD070 = 1
    PD144 = 3000
    You need more settings than that to have one of these spindles run correctly they are some of the main basic settings and not enough to make it run safely
    Have you checked the 4th pin at the spindle to see if it is Grounded to the spindle body, if it is not then this has to be corrected before moving forward
    What is in the Email last post regarding the wiring is not correct the input power should be connected to R and T Terminals and Ground to the Ground terminal
    Mactec54
    May 2019
    41
    May 2019
    41
    May 2019
    41
    I will take off the cover and take a picture. Also check the ground.
    May 2019
    41
    Why am I getting double posts?
    15362
    That happens some times just watch you don't hit reply twice
    Mactec54
    May 2019
    41
    I was really hoping you would respond to my post. Most of everything of any value that I read has been by you.
    15362
    Is your spindle air cooled or water cooled
    Mactec54
    May 2019
    41
    Air Cooled. I will get to shop today and get those pictures. I am quite sure pin 4 isn’t grounded to spindle body though. It may not be used at all.
    May 2019
    41
    Pics attached.
    1 - input wiring R,T and earth ground
    2- disassembled connector and ran Pin 4 to body of spindle motor Should it also be grounded to VFD? Would be an easy fix since there is a wire running to VFD IN CABLE.
    3 - picture of my set-up
    Attached Thumbnails Attached Thumbnails A6E6D260-1497-4177-B837-124CBEC2A8BE.jpeg   3FA825B1-0804-4B36-87EE-5C398B5766AB.jpg   BC30149D-B579-4ADF-8B4A-29B6012DC6AC.jpg
    15362
    Pics attached.
    Are yes you can not use that type of cable and the Ground wire will output lots of EMF wired like that, you need a 4 wire Shielded cable I'm surprised that you ever had it running wired like that
    The Cable you need from the VFD to the Spindle needs to be like this CF6015-04 and connect the Ground to the spindle 4th Pin in side the spindle , the cable wires can not be unshielded like you have it wired the insolation must go inside the plug
    So with a new cable don't take the insolation off the wires like that
    You get this cable from IGUS or other suppliers
    Here are some snips of how the cable has to be used and prepared for connection
    Mactec54
Page 1 of 4 123
  1. Replies: 18
    Last Post: 11-07-2020, 01:48 PM
  2. Spindle problems . What is the runout on your spindle?
    By eltejano in forum Tormach Personal CNC Mill
    Last Post: 04-05-2017, 06:56 AM
  3. KM3 Spindle Problems
    By efinkg in forum HURCO
    Last Post: 06-12-2011, 03:03 PM
  4. more spindle problems
    By groundhog719 in forum Syil Products
    Last Post: 04-26-2011, 05:39 AM
  5. SX3 Spindle problems. Need help
    By tranbell in forum Syil Products
    Last Post: 07-21-2009, 06:43 AM
