587,104 active members*
4,223 visitors online*
Results 1 to 5 of 5
    Apr 2011
    9
    Feeds & Speeds
    I was wondering what kind of feeds and speeds you guys run....
    17-4 Stainless Steel HT:
    Sandvik CNMG-433-SMR-1115 for Roughing
    .120 Depth of cut
    400SFM
    F.012
    Insert Normally runs for about 15-20 parts.
    4340HT
    Sandvik CNMG-433-MR-4215 for Roughing
    .120 Depth of cut
    650 SFM
    F.012
    Insert life 15-20 parts.
    Thank you!
    Dec 2010
    25
    We run a lot of 4340. We always run a Valenite WNMG432 NM6 WPP10 for roughing. We do about .100"- .150" depth of cut at 800 S.F.M. and run at .009"-.013 I.P.R. We get approx 50-80 pieces per edge. We tried Sandvik, Kennametal, and Iscar. They were decent, but the Valenite really excelled. 4340 can really be a pain, and we experimented for a looong time with this material.
    You will not be upset with the results if you try the Valenite.
    We run one 17-4PH job, but we make a lot of pieces annually. It is a tricky material. I don't take the depth of cut your describing, but I have had great luck with a CNMG 332 (Kennametal brand, can't remember details). I run the SFM around 200-300 and feed up to .01" per rev. What I notice about 17-4 is that the material is not consistent from batch to batch. I have had some stock that ran wonderfully, and some that I had to re-write all the speeds and feeds to get good tool life. Can be tricky. I'd rather have 303 or 316 S.S. than 17-4. It changes a lot.
    Good luck to you!
    Progressive Turnings, Inc.
    www.progressiveturnings.com
    Apr 2011
    9
    Thank you...
    I have the same problem in 17-4 SS...sometimes it runs great and sometime like crap.
    The sandvik 1115 grade really impressed me. Iscar 907 grade not so much.
    Dec 2010
    25
    Iscars 907 didn't work well for me either. I like Sandviks 1115 grade, but there 1025 is better, in my opinion.
    good luck to you
    Apr 2011
    9
    What kind of feed and speed....depth of cut are you running with the 1025?
    I never used the 1025 before...might have to give it a try.
  1. Speeds & feeds
    By nateman_doo in forum Benchtop Machines
    Last Post: 11-21-2011, 02:54 PM
  2. speeds and feeds
    By dek in forum RFQ Feedback
    Last Post: 03-16-2010, 05:23 PM
  3. Speeds and feeds (I know, I know)
    By mrcodewiz in forum Benchtop Machines
    Last Post: 10-18-2008, 09:00 AM
  4. Help! with Feeds and speeds please!
    By sjotime! in forum Visual Mill
    Last Post: 02-13-2008, 07:56 AM
  5. feeds and speeds
    By JpBinc in forum MetalWork Discussion
    Last Post: 10-03-2006, 06:48 AM
