588,525 active members*
4,862 visitors online*
Results 1 to 3 of 3
    Nov 2009
    82
    point machining tool path pattern
    WIthing a point unit, circle mill, I have two tools sequences inserted both with the same tool. I also use a line geometry selection.
    i am fairly sure this is a parameter issue but I can't find it.
    The tool does the first tool description for the first line goemetry, then goes to the second line geometry position, then back to the first line geometry position to finish with the second tool inserted, and finally to the last geometry.
    I want the machine to finish out the unit geometry in the first position of the line before moving to the second line geometry.
    There are a lot of rapid moves now between the two line geometries.
    Dec 2007
    300
    priority numbers 1 for rough 2 for finish.
    Dec 2007
    300
    If you want to rough and finish each hole in order use separate units for each one and use a different priority number for each units tool. Use priority 1 for rough and finish first hole and priority 2 for second unit.
  1. CAM: Tool path generation for ATC Automatic Tool Changer
    By S.Seveelavanan in forum Uncategorised CAM Discussion
    Last Post: 08-09-2012, 04:45 PM
  2. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  3. Going off Path During Machining
    By artiesag in forum Mach Software (ArtSoft software)
    Last Post: 05-15-2010, 03:41 AM
  4. Replies: 1
    Last Post: 11-27-2009, 08:24 AM
  5. why Tool move back to reference point everytime during machining
    By luckyyyyyy in forum MetalWork Discussion
    Last Post: 08-18-2009, 08:31 AM
