588,201 active members*
4,401 visitors online*
Results 1 to 7 of 7
    Sep 2014
    4
    Varying spindle speed
    Hi, Having problems with vibration when machining shafts. The control system I am using is the Fanuc O T series. I have read a few articles about using a macro to vary the spindle speed thus eliminating the vibration. At the moment having to do this manually. Can anyone shed light on how to create a macro in a program? The machines are a Victor and Daewoo CNC lathe. Also machining in imperial.
    Aug 2014
    7
    Re: Varying spindle speed
    clear the interference in command voltages(0-10v).not seriel spindle. you can get perfect speed...
    Sep 2010
    1230
    Quote Originally Posted by ally6677 View Post
    I doubt very much that you could do this successfully with a User Macro Program. You can't have the Macro Program running in the Background varying the Spindle Speed, whilst the machining program is being executed. The only way I can see you doing this with a Custom Macro program would be to break the tool path up into many segments and vary the speed at the intersection of each segment.
    Controls that have this feature inbuilt achieve the result via the PLC program.
    I'd be interested in seeing the article you referred to if you're able to Post a link to it.
    Regards,
    Bill
    Dec 2012
    22
    Maybe the OP is looking for something like this:
    #100=500 (part length)
    #101=10 (travel length before speed increase)
    #102=50 (rpm variation every #101 distance)
    #103=300 (spindle RPM)
    #104=#103 (rpm counter)
    #105=0 (counter)
    G0G90X()Z.1M3S#103
    G1Z0F50
    WHILE[#105LT#100]DO1
    G91Z-#101F50S[#103+#102]
    #105=#105+#101
    IF[#103GT#104]THEN#102=[-#102]
    IF[#103LT#104]THEN#102=ABS[#102]
    END1
    G0X()
    Etc...
    This macro will vary the RPM by 50, either up or down, through the entire length it is turning the part. Change the #100 variables accordingly to fit your application.
    Kind Regards,
    Paul
    Sep 2014
    4
    Thanks. I'll try this when I get a minute and I'll let you know.
    Ally
    Sep 2014
    4
    Thanks for the replies guys. Paul I will try this tomorrow. Many thanks for your help.
    Ally )
    Dec 2012
    22
    By the way... I found this macro on another site... therefore cannot take credit for it's creation.
    Just trying to help the OP.
    - Paul
  1. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  2. Need help with varying tip voltage/ poor cut quality
    By binfordw in forum Hypertherm Plasma
    Last Post: 03-30-2012, 12:25 PM
  3. Varying zero for cutting on non flat surfaces.
    By zonker in forum Mechanical Calculations/Engineering Design
    Last Post: 01-13-2010, 05:34 PM
  4. engraving a piece with varying thickness?
    By theclive in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-25-2007, 10:26 PM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
