587,608 active members*
3,321 visitors online*
Results 1 to 10 of 10
    Jun 2020
    Unhappy Im a dumb student.....
    Hello everybody i hope all is well, Let me just briefly explain my situation, im currently doing an internship at a plastic manufacturing company and they have many HAAS machines and im well able to use them, but they recently purchased a doosan Puma 280LM with a Fanuc oi -TC controller, so far i have been able to send jobs too it over Ethernet (I created a virtual com port)
    ANYWAYS My question is very ambiguous all im trying to do is start the job and setup tool changing but im LOST, when i try starting it it says IMPERFECT WORD must be changed..... Any help would be fantastic, and also have no clue about the tool calibrator, when i push it down it just goes backup...
    Rebededes Guest
    Re: Im a dumb student.....
    Good post i like it.
    Jul 2005
    380
    Imperfect word means the Fanuc cnc doesn't recognize what you've fed it.
    Example? Pictures? Code?
    I used to work for Doosan, and I have the training manuals I wrote, if you'd like.
    Sep 2007
    66
    hi
    when in manual guide the softkey start is pushed [softkey]
    you can select start program , start new operation , ect
    when you select start program
    something like apears
    G54
    G40 G80 G90
    G50 S2500
    T?
    G? (G96/G97) S? M03 P11
    every time you see a "?" sign, you change the word
    So T? for example
    first select the word so that T? becomes yellow
    then you type 0101 for tool nr 1 offset nr 1, and the press the alter key
    then it says T0101
    same is for all the other "?" signs
    hope this helps
    https://manualzz.com/doc/23340305/ma...rning-examples
    greetings bertus
    Attachment 461424
    Sep 2007
    66
    hi
    try cleaning the base of the arm .
    or push the button ones
    bring the toolpoint close to the thing with the 4 thingies ,and then move the tool in jog mode to the sensor
    this sould go slow and if made contact it will auto retract and make the change in the offset for that tool
    greetings bertus
    Nov 2007
    364
    Why are you not in the NC programming screen ?
    Sep 2007
    66
    Nov 2007
    364
    Yes on that machine there is another NC screen right ?
    You are on the simulation side of things ?
    Sep 2007
    66
    hi
    No this is the EDIT "side" like it say's on the top rigth corner of the screen in manual guide I
    Attachment 461488
    greeting, Bertus.nl
    Nov 2007
    364
    I think it is on the System Screen i just cant remember but it says NC and it is white with black lettering ---------Only time i ever seen or used that side was for simulation and its blue and grey ---------------These are the Fanuc quick edit screens and stuff and really are an other attempt at conversational programing --------Good luck
