587,936 active members*
5,998 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Problems sending files to OSP5000 over RS-232
Results 1 to 20 of 23
    Mar 2004
    368
    I know there are a lot of threads on this, but I searched them all and can't find the solution.
    I have an LC-40 with the OSP-5000 control. I have a RocketPort (just a board with a lot of COM ports) connected to the PC, which runs Windows 98. I am using NCNET lite to transfer the program.
    I made up the special serial cable according to instructions I read online. Bit parameter 1 is set to 00011011 and parameter 12 is set to 00100010 (some suggested the left most bit of parameter 12 should be 1, but when I enter a 1 it always changes it back to 0).
    The baud rate is set to 4800, even parity, 7 data bits, 2 stop bits.
    I am able to send programs from the machine to the PC with no problem - it works every time. I do this by going to the PIP menu, pressing the PUNCH key, then the command I use is "PUNCH ABC, CN0:" and it works.
    When I try to send files to the control from my PC, it gives an error about 50% of the time, and when it sends it correctly, the file is either blank after the file name, or it contains some error codes the NCNET program sends, or it will have the complete program, but every 10 or 12 lines there will be several characters or a whole line missing.
    I have tried changing all the settings in the NCNET program. If I adjust the # of stop bits, I get parity errors on the control. I have tried changing the flow control from hardware, software, none, both in NCNET but it always seems to do the same thing.
    If I try to change the baud rate in the control (and on the PC) from 4800 to 2400 or 9600, I can't even send from the control to the PC - the file is all just garbled... but at 4800 baud it works every time, never a problem.
    But I can't seem to send any files from PC to OSP5000.
    I type "READ CN0:" and hit enter
    If I don't get an error, then it will create a file called A.MIN, but when I look at this file, it will either just be the filename ($FILENAME.MIN%) and then blank after, or it will be the program, but have characters missing in various points or even a whole line or two missing.
    Any clues?
    Driving me nuts!
    Mar 2009
    1982
    First of all. Please, take in mind it will not be ein zvei and ready. It will take time.You have communication working, fortunately, it makes the task much easier.
    post it's diagram here. Take into consideration, please, the fact, that communication works as a complex of wiring, connecting and parameter settings. There are many combinations working. Do not mix something from one to another.
    Do You think, that it is all the same for every control? OK, lets check, what it means:
    NC optional parameter (bit) parameter#1:
    bit 0 = 1
    tape code. for ISO, must be =1.
    bit 1 = 1 recognize tape code automatically. mus be =1 for adjustments at least
    bit 2 = 0 TV check. 0 is correct - no TV check.
    bit 3 = 1 tape delimiting code set to ISO. correct
    bit 4 = 1 verifies tape during reading. Are You verifying? I would suggest 0 for adjustments and to leave without verifying for ever.
    bit 5 = 0 rewinds tape. 0 is correct- no rewind.
    bit 6 = 0 handles special code as an alarm. =0 this bit, no alarm while special code is correct.
    bit 7 = 0 does not store special code. same as above (bit 6) =0 is correct.
    Let's see, what it is:
    bit 0 = 0
    bit 1 = 1
    bit 2 = 0 file name output for tape punch out. "0" is for output. Correct
    bit 3 = 0 end of record code for tape punch operation in ISO code. I would recommend =1 to have only LF
    bit 4 = 0 code used for tape feed for tape punch operation. =0 is correct: null
    bit 5 = 1 specifies whether tape feed portion is punched. =0 is better: not punched
    bit 6 = 0 communication link is reset by pressingg NC reset button. does have no influence
    bit 7 = 0
    hand shaking problem, most likely. Is Your PC communication program using hardware handshake?
    it's good to have two stop bits on OSP side.
    Cable length?
    If baudrate 9600 doesn't works, You need to see the serious problem.
    Feb 2009
    6028
    OK, this can be frustrating for sure. "if" I remember correctly, and it been a while on the 5000, after you change baud rates on that control, you need to press the backup softkey then cycle the control power. Keep in mind it's been a long time for me on that control, so i'm going off a very fuzzy memory.
    Apr 2009
    1262
    Underthetire is on the money, but even Okuma doesn't tell you that when you backup and cycle the power, be sure to turn off the breaker for at least 30 seconds or the RS board doesn't properly reset to the new parameters.
    Apr 2009
    1262
    Based on your description, you are having a handshaking problem. Turn on software handshaking (XON/XOFF) and make sure it is matching on the PC side.
    After receiving the file name, the Okuma will "XOFF" to create the file in memory and then "XON" for another 256 characters. Then it will "XOFF" again to save the data, and "XON" for another gulp of info. This repeats until it sees the file delimiter.
    Clues: If getting garbage characters, baud rate is not matching.
    If getting chunks of good data, but missing sections, Handshaking is not working.
    If getting no data out or in, cable is bad.
    Always try punching data first. PC's are better at receiving and will get you a good file with good format to send back to the Okuma.
    Best regards,
    Dec 2008
    3136
    One thing that has not been stated is that the PUNCH and READ settings are independant ( they have seperate settings )
    You've got the PUNCH settings down pat, now find your READ settings and adjust them ( they should be very similar ), the PC transfer software may also have a similar config that sending and receiving are also seperate settings.
    If you have a program like below
    Code:
    $FILENAME.MIN%
    (TEST FILE )
    M30
    When <PIP> <READ> CN0: <WRITE>
    the file should be downloaded into the control as FILENAME.MIN
    When <PIP> <READ> CN0:, <WRITE>
    the file should be downloaded into the control as A.MIN
    When <PIP> <READ> CN0:,ABC <WRITE>
    the file should be downloaded into the control as ABC.MIN
    MIN is a default extention and is not required, the comma after CN0: is a rename operation and if no name is specified after that comma then A is the name given
    Oct 2009
    119
    Hi everyone
    We have this ports on lathe machine. We want to communicate with serial
    port. It is not RS232C (female). Serial on picture is male.
    How to communicate ?. Is it same with RS232C procedure ?.
    Jul 2007
    154
    Re: Problems sending files to OSP5000 over RS-232
    Quote Originally Posted by SRT Mike View Post
    Any clues?
    Driving me nuts!
    Im digging up an old thread here I know, but Im having a similar issue with my very old green screen OSP5000. Did you resolve this if yes what did you find? Do you use a BTR?
    My machine has a BTR, that used to work fine, now I cant send.
    Mar 2009
    1982
    There are many simillar points between regular RS232 and communication with BTR.
    "Hercules" is a Windows application very helpfull for communication diagnostic and adjustments.
    Jul 2007
    154
    With the LB15 all fixed, my next task is to tackle the LS30N coms issue. It's an early 5000 green screen and I'm told it can't use the serial port even though it has one. This is why it has a BTR. is this true?
    I have your settings from an earlier thread I'll start there.
    Mar 2009
    1982
    is this true?
    Only in case if it's damaged, which also is not likely. Okuma RS232 interface is very resistant.
    check if DB-25 is wired.
    Jul 2007
    154
    Quote Originally Posted by Algirdas View Post
    Hmmmm well my 5000 green screen 100% does have a wired DB 25pin port on the machine (same as the LB15) and right next to the DB25 there is also a round plug and behind the round plug the BTR is wired into.
    So do you think the reason the BTR was used was because back in the day they did not know how to use the serial port?
    I recall someone once telling me that the very early OSP 5000 did not have a functioning serial port, thus the BTR. But this could be wrong.
    Jul 2007
    154
    FYI My OSP 5000 green screen lathe is year 1981
    Jul 2007
    154
    Algirdas please take a look at my video below. Saves me typing 1000 words!
    The original DB25 is wired but it has never been used. The machine was fitted with a BTR long before we got the machine, and we used the BTR for many years. Now I have no coms and was wondering can I use the DB25 serial connector rather than the BTR?
    https://youtu.be/AeraWEQ9Jls
    Mar 2009
    1982
    1. Why the BTR was used?
    I have no idea. Maybe there are some advantages. Drip feed, for instance.
    2. Original TR. Usefull only in case if you need to use paper tapes.
    3. Serial port. I would check Read CN0:, and, if doesn't work CN1:
    Jul 2007
    154
    We purchased the machine 1999 from the original owner who purchased it new in 1981. I understand it was one of the first Okuma lathes commissioned in Australia and certainly the first LS30-N. I'm also told that the BTR was installed because they believed these earliest versions of OSP5000 machines could not support serial communication another (conflicting) story is that the techs back that did not understand how the coms worked and so installed a BTR to get around the lack of understanding.
    The BTR used to work fine and frankly I have no issues going back to using it, but right now I have no coms, I have spare RS232 boards but none fix the problem. Which leads me to suspect that the BTR is bad thus my idea to try and get the serial port working and dump the BTR.
    Lastly why is my send command using PUNCH NAME, PP: rather than CN0 or CN1? What does the "PP" mean?
    Apr 2015
    3
    Video BTR is a punched tape connection, i.e. parallel in a way. I used to do those conversions with such cards and later with programmable converters (parallel-serial RS232).
    The oldest 3000 and some of the first 5000 series had a punched strip in one direction and RS232 in the other
    With a serial port cable and using the TT: method of my post, you can do better. Some 5000 models require RTS/CTS handshake and some handshake from D25 pin number 20. You should be careful if you don't know what you are doing.
    Jul 2007
    154
    Quote Originally Posted by IguSystem View Post
    Thank you, good info, I'll give it a try! Question, why would this machine have a BTR installed? I understand its been in play from day 1.
    May 2016
    26
    Could you solve the problem?
    What serial communication software are you using?
    I’m using COMMUNICATION SOFTWARE FOR FANUC CNC with the similar CNC.
    It is specially designed for FANUC CNC though it can be used also with other CNC.
    It has several built-in help menus that show you how to use it with your CNC.
    You can download it from “The SOFTPEDIA· web page.
  1. Problems sending files to Prototrak MX2
    By Lugy in forum Dolphin CAD/CAM
    Last Post: 03-03-2016, 05:08 PM
  2. Sending files to cnc
    By cbscnc in forum CNC Machining Centers
    Last Post: 07-02-2013, 01:25 PM
  3. Need help sending files
    By Sierra VF2 in forum Haas Mills
    Last Post: 01-30-2013, 06:59 PM
  4. HELP SENDING FILES
    By Sierra VF2 in forum GibbsCAM
    Last Post: 01-30-2013, 01:47 AM
  5. sending and receiving files
    By ashro in forum OneCNC
    Last Post: 02-08-2011, 09:04 AM
