587,691 active members*
3,644 visitors online*
Results 1 to 11 of 11
    Sep 2006
    34
    CNC doming machine
    I finally finish the doming machine project.
    [ame="http://www.youtube.com/watch?v=z5_H_WVbz98"]YouTube - Doming application small decorative labels[/ame]
    The machine.
    Parker linear motion tables 406 & 404 series
    Drives 750 OEM
    Motors nema 34
    All from ebay.!
    Mach3
    Feb 2006
    210
    Wow George!
    I like your machine. I have a cnc router and use it to make patterns for my aluminum foundry. We often fill the castings(medals etc) with epoxy. I will have to explore this as a way to automate this arduous part.
    Thanks.
    Dave
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Aug 2005
    1622
    Very impressive George. Your metering of the liquid seems pretty accurate. Is that a custom valve?
    We use some darned expensive metering valves from loctite that can handle MEK based glue that ruins rubber seals and diaphrams of others we have tried. The nice feature these have is suck back effect to minimize stringing and drips. Very complex internals with the metering control and pneumatic actuator.
    I have an 18" x 18" x 12" 3 axis assembly that may become a glue path apparatus very similar to your applicator. It is all Parker Daedal ballscrew slides, with Compumotor motors and drives that someone scrapped at a friends scrap yard.
    The plan would be to make it assistive for mobility and visually challenged employees. Loading and unloading a pallets of parts would eliminate the hand gluing and alignment issues.
    Nice video!
    DC
    Sep 2006
    34
    Quote Originally Posted by One of Many View Post
    W
    DC
    thanxs DC..!
    I have to tell you that I build a small cnc ROUTER to machining a lot of part for the big one!
    The valve is a pinch valve that I build!
    The pumps this a strange story!
    I use Viscotec Progressing Cavity Pumps Which cost about 5.000$ each.
    I need 2 since the doming application is a two component.
    I found from ebay 5 for 50$ each (3 new 2 used).
    I was Lucky!
    George!
    Aug 2005
    1622
    Quote Originally Posted by GEORGETOUBALIS View Post
    thanxs DC..!
    I was Lucky!
    George!
    Our system didn't require that precise of metering the auger or screw pump will give. We use a large pressure pot that holds a 5gal bucket of the adhesive. I needed to have a valve that was positive off without leakage, drips or strings. This fit the bill without complicating the mess with electronic drive circuity. Just a simple pneumatic micro-switch on a linear cam.
    Here is a look at the Loctite metering valve we use. Last ones we purchased were $950usd or so with rebuilds/repair about 1/2 that. That looks cheap compared to those pumps! You did get lucky. Careful though, that ebay
    Loctite 97113
    DC
    Sep 2006
    34
    Loctite 97113
    DC
    One component dispensing is very easy process compared to 2-components.
    Last year I purchased from Ebay the same valve as you (never used in there official BOX).
    I want to make a 2 part shutoff valve by connecting some way 2 one part but then (after a month) I found 2 Garco 2-part valves (2500$ per valve) for only 250$. And I use these now.
    I wiil sell sometime soon the Locktite valves! I do not need them any more!
    Ebay is a paradise!
    I will spent about 18.000$ the last 2 years and I have
    A. 2 cnc tables
    B. components to build another 2 much bigger (motors, drives, power supply, sensors, linear tables, linear rails, ball screws ........everything.
    C. 4 dosometric systems 2 for one component 2 for 2-part component
    90 orders in total ! with no problem at all.
    I think you have to give ebay a try!
    Aug 2005
    1622
    Yes, I would say that 2 part dispensing does add some complexity, not to mention the ability to cure in the nozzles. Cleaning them well must be a chore?
    I have used Ebay on about the same number of trades over the last oh, 10-12 years. Most good experiences but not all . There is the occasional thief on the prowel that don't care if you like what they sell. Once they have the cash, they intend to keep it, regardless if the buyer doesn't consider it a fair trade on a sight unseen sour deal. Ebay policy is no help, even when the sellers listing includes a return/refund policy if you are not satisfied.
    DC
    Jun 2010
    quotation Required
    Dear Sir,
    Pleasr Quote for scripting Doming machine.please give your technical literature.
    The machine.
    Drives 750 OEM
    Motors nema 34
    All from ebay.!
    Mach3
    Apr 2003
    312
    George,
    I was fascinated with the video!!! Your brilliant application of a CNC process works to perfection!
    Senna
    aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
    Dec 2008
    HOW MUCH IS YOUR DOMING MACHINE? OR CAN YOU HELP ME BUILD ONE FOR MYSELF?
    Aug 2010
    Smile Director
    The machine.
    Drives 750 OEM
    Motors nema 34
    All from ebay.!
    Mach3
    Kindly send us quote
  1. Another machine rigid tapping (stepper machine)
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 02-12-2019, 05:53 PM
  2. saleCNC laser engraving machine and CNC woodworking machine
    By zhangrui1588 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-08-2011, 09:54 PM
  3. sell CNC Woodworking Machine,CNC Advertising Machine
    By zhangrui1588 in forum News Announcements
    Last Post: 05-30-2008, 02:43 PM
  4. Deep Groove Taig machine would it be a good starter machine
    By Fritzie15 in forum Taig Mills / Lathes
    Last Post: 09-21-2007, 03:37 AM
