587,207 active members*
3,010 visitors online*
Results 1 to 11 of 11
    Jul 2018
    87
    Need help with relay on usb card bsmce04-pp bob
    Can anyone please explain to me how to wire a 5v relay to a usb bob. I have done the installation of the RnRmotion.dll ,all limit switches and drivers are working except relay .please see attached pics of relay, bob and diagram
    Thank you in advance
    35538
    Re: Need help with relay on usb card bsmce04-pp bob
    Do you have any more info on the relay board, or more pics?
    You should just need to wire one of the outputs from your RnR board, along with 5V and COM.
    Mar 2007
    2083
    putting together data from various web sites this is as close as I can get to the circuit of the dual relay board
Name:	relay board circuit.jpg
    with the jumper JD connecting the two VCC terminals
    Attachment 404410
    on the 4 pin connector
    you will need to connect a 5V supply to the VCC & GND terminals
    the GND needs to be connected to the USB controller GND and output to IN1 (or IN2) on the relay board
    John
    PS
    do you have a link to a manual for the 4 Axis Interface Driver Motion Controller ??
    assuming the part of the board with the micro controller is powered by the USB port
    it's not clear from the photo how the opto-isolated outputs and inputs are powered or
    what the IC next to the four outputs is
    can you read the part number ?
    Attachment 404422
    Mar 2007
    2083
    found a photo on the net that shows the 16 pin IC connected to the outputs is a ULN2003
    Attachment 404430
    pdf data sheet
    Attachment 404436
    terminal DCM (next to input IN1 ) looks like the positive supply for the input & output circuits
    going by the value of the resistors on the pcb it should be OK with +24V
    the negative supply being the common connection for inputs IN1 to IN4 and outputs out1 to out4
    John
    Mar 2007
    2083
    update
    after finding more a detailed view of the board
    this is the input and output connections on the board
    Attachment 404640
    with this information the answer to the original question
Name:	relay board connection to motion controller.jpg
    the e-stop or limit switches are connected between the common DCM terminal and one of the 4 inputs (IN1 to IN4)
    the relay board's GND needs to be connected to the motion controller DCM
    one of the motion controller open collector outputs (OUT 1 to OUT 4) needs to connect to
    one of the relay boards inputs (IN 1 or IN 2)
    john
    Quote Originally Posted by john-100 View Post
    update
    Attachment 404640
    john
    Could the +5v from the usb section of the controller be used for the Vcc on the relay? Or is that a bad idea?
    hi all
    some body know, how I can connect the limit switch in this board bsmce04-pp, and also I want to connect Diode Laser, which is the correct connection the lase is PWM or TTL
    thanks, AR
    Mar 2007
    2083
    is your laser diode like this ?
    Attachment 418412
    if it is connect the enable to the + supply and
    TTL input to the bsmce04-pp PWM output
    I don't have a detailed manual to know if you can use one of the 4 outputs (output 1 to ouitput 4)
    john
    hi John good afternoon
    I want to add one laser as the link bellow.
    https://www.ebay.com/itm/15W-Laser-H...E/372196328146
    I am not sure how to connect it in my CNC 6040, the is the board pcb that's it have see attach picture
    hi John Good afternoon
    My laser is different it is for TTL and PWM, but I want to know how I need connect it, want to control the intensity directly from my control.
    https://www.ebay.com/itm/15W-Laser-M...Y/282862694217
    thanks, regards.
    Mecanico3020
    Mar 2017
    411
    I know this thread is old but for heavens sake man who taught you how to wire?
  1. Help usb smooth stepper bsmce04-pp on plasma
    By Bradnicent in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 10-18-2018, 10:03 AM
  2. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  3. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
