587,126 active members*
2,984 visitors online*
    Jul 2011
    6
    Help!! Is Masso a 5 axis option
    Hi all, I’m seeking guidance, I’m looking for a 5 axis simultaneous mill controller and I am considering a Masso G3 touch, I’m retro fitting an old mill, 11kw 9k spindle 1kw XYZ 400v servos 16 tool ATC BT40 and looking at building my own 4/5 axis trunnions table on harmonic drives and AC servos.
    A lot of people seem happy with Masso on 3 axis machines but I don’t know how well they work on 5 axis, they say it can do it but I can’t find anyone that’s done it. The only vid out there I can find is a G2 and it cannot handle different length tools so a ATC is out of the question.
    Any help, leads or links would be much appreciated.
    Thanks for your time.
    Regards [email protected]
    Re: Help!! Is Masso a 5 axis option
    If you want to get into 5-axis continuous machining you need an RTCP capable CNC as well as the Rosetta CNC has.
    RTCP is very important with 5 axis for a lot of questions but overall to get a fluid movement in any case.
    Take a look at:
    Or at this preview of new UI vertical touch:
    Sep 2011
    23
    I would think Masso themselves should be able to help with this information, surely they would get enough customer feedback to know if someone is using 5 axis?
  1. MASSO-G3 CNC Controller Up to 5 Axis
    By automationtechinc in forum News Announcements
    Last Post: 05-06-2021, 06:20 PM
  2. Replies: 0
    Last Post: 06-09-2016, 03:25 PM
  3. c-x contouring option vs y-axis lathe
    By hydrospin01 in forum Okuma
    Last Post: 04-04-2015, 10:09 PM
  4. 3-axis DRO...which is better option.
    By RX-Heven in forum Benchtop Machines
    Last Post: 05-12-2011, 07:15 PM
  5. a axis for lath option
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 06-21-2009, 12:44 AM
