587,593 active members*
4,075 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > UCCNC Control Software > Converting to UCCNC & UC300ETH-LPT5 (From Mach3/PP/SS)
Page 1 of 2 12
Results 1 to 20 of 30
    Jan 2008
    241
    Question Converting to UCCNC & UC300ETH-LPT5 (From Mach3/PP/SS)
    Hello,
    Just getting things setup up and running with the new hardware/software.
    I had the system up and running with Mach3 and through the parallel port.
    I was loosing steps due to the PP card issues.
    I got a hold of a smoothstepper for a week and had it running with a couple of clicks.
    Everything works no wiring issues...
    Now I have a UC300ETH-LPT5 and the software loaded up and plugged in, UC300 detects (And flash auto updated)
    Everything powered up, everything connected and I created a new profile and imported my Mach3 profile.
    (PP cable plugged into port 1 of the UC300)
    The limit switches work. The emerg stop works. The probe works (all signalling correctly through the Diags page)
    The motors lock up, but wont turn? Can't get the spindle to cycle on/off.
    I can't change the STEP/DIR pins, when I change them and click apply, they revert back to zero.
    Thoughts?
    Thanks!
    Attached Thumbnails Attached Thumbnails P_20170405_195131_vHDR_Auto.jpg   P_20170405_195207_vHDR_Auto.jpg
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
    Dec 2010
    634
    Re: Converting to UCCNC & UC300ETH-LPT5 (From Mach3/PP/SS)
    I'm not in front of my controller but, I think if you change a value and hit apply, it will revert to whatever it was before. You have to change a value, hit ENTER, then hit apply. You can change as many values as you like before hitting apply but you MUST hit enter when you're done changing a value for it to stick.
    I know for a fact that's true for most numerical settings. If that's not it exactly, it's something similar to that to get the value to stick before hitting apply. I kind of recall having the same issue a few years ago.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Jun 2015
    943
    Pin settings revert back to zero if the setting is not valid and that means that you trying to set an output pin to an input function or an input pin to an output function. the software verifies this and nulls out the value if the setting is invalid.
    Jan 2008
    241
    Okay, thanks,
    So gotta hit enter, then apply, then save.
    If you try to enter an invalid setting, UCCNC wont let you. Good to know.
    What setting I'm missing to get the motors turning?
    Jun 2015
    943
    Step port and pin is 0 on your picture so the software will sure not move your motor with these set to 0.
    35538
    You can only use ports 2 and 3 for what you're doing.
    Ports 1,4, and 5 use pins 2-9 as inputs, which is why it's not working for you.
    You DO NOT need to click Enter IF you use the up/down arrows to select the port and pins. But you DO need to click Enter if you type the numbers in, like in Mach3. (But there's a setting to remove this requirement)
    Jan 2008
    241
    You can only use ports 2 an 3 for what you're doing.
    I was thinking that. Watched a couple videos and saw the PP cable in port 2. Ill make the switch tonight after work and let you know.
    35538
    Before I posted, I tested it, and when entering port 1, the values reverted to 0's, but when you use port 2 or 3, they take.
    Jan 2008
    241
    Cool Re: Converting to UCCNC & UC300ETH-LPT5 (From Mach3/PP/SS)
    Okay, good news. I got movement!
    The Mach3 import didn't pull all the setting over, so I had to go through them all and verify.
    Biggest problem was I plugged into port 1 instead of port 2.
    Once that was done, set up the STEPs and DIR pins and I had movement!
    I installed the 2017 screenset. The Auto Zero macros works as they should, but I'll probably need to tweak the Post Processor to enable the tool change?
    I'm using my old PostP from Mach3 (Mach2_3_ATC_Arcs_inch from Aspire)
    I made a simple two tool toolpath for testing.
    - I first homed the machine
    - Then I ran the Auto Tool Initiate
    - I loaded my code and hit CYCLE START
    - The code ran through to the tool change(The tool was already in) so I hit CYCLE START again.
    - The Machine dropped Z to my safe Z height, and scooted across the table
    - It never went through the sequence of Zeroing the installed tool
    - I let it finish the first tool code
    - When it finished, the spindle shut off, Machine moved Z to safe Z and stopped
    - The Machine did not move to the tool change position
    - I hit CYCLE START again, and the code continued on through toolpath 2
    - When the code finished, the spindle shut off, and the machined moved to the park position.
    - What I found I can do, is once the spindle is off, and its waiting for the tool change, I can click the 'Goto tool change position'
    - There, I changed the tool, then hit the Auto Zero (machine then zero'd)
    - Hit Cycle Start, and everything ran as it should.
    I'm sure it runs like it did in MAch3, and I'm also pretty sure I've missed something again LOL
    This is my first run/test with the new setup.
    First and biggest thing I noticed was how smooth and QUIET the steppers where! (AMAZING!)
    Gerry's screenset is once again awesome! - So easy to use and move around in.
    Couple notes:
    - There is no 'Recalculate Toolpath' like there is in Mach3?
    - The text in the gcode text window is hard to read due to the colors used.
    - The graphical preview window is nice, but takes a little getting used to as it doesn't show the entire table, just the working area.
    - On the 'CLOSE FILE' button, I would like to see an 'Are you sure' pop-up (I miss clicked it instead of Rewind and lost the code)
    - The CPU usage is was around 6-9% while running in Mach3. CPU usage in UCCNC is 1-3%
    - I would really like to see a 'Verify' feature added... Just for piece of mind.
    More to come as I get some time to play, but so far I'm liking this new setup!
    35538
    Did you only have one number for both (all?) tools? I believe that it only zeroes the tool if the number changes. If it's the same tool, it doesn't re-zero it.
    I'll have to go back and look into that tomorrow, but I think that's how it works.
    If that's the case, there should be a message - "Tool Change ignored - New tool = current tool"
    I would not do that. It should be going to the tool change position.
    If your tools do have different numbers, send me the code, and your profile, and I'll look into this.
    No, because there's no need for it. If you edit the code, it will recalculate automatically.
    Mach3 sometimes required it, but UCCNC doesn't.
    You can change all of the colors on the Settings page.
    Jan 2008
    241
    Hi Gerry, technically, its one tool, I did however change the tool number for each toolpath I made.
    (Specifically for this test)
    - It's not going to the tool change position, the machine cuts the toolpath, then stops at the last code, as raises to home position (1.5")
    - I hit Cycle start, the spindle winds up, and it moves to the next code.
    Good to know about the recalculate.
    Attached is the GCode, and the (zipped) VCarve files.
    The next problem I have is the circles are not round?!
    I guess there are no ARCs in UCCNC yet?
    Also, the GCode that gets created by Aspire, UCCNC says there is unknown gcode?
    Same PostP I used for Mach3.
    Thanks!
    Jan 2008
    241
    Okay, after a little more reading and trial...
    I've found that because I'm still in the imperial age, I needed to adjust the 'Linear and Corner Error' settings.
    - I'll fine tune these later...
    Rounds came out round, but there was a noticeable slowdown, and jerky movement in the rounds.
    Now to play with the Post processor to figure out what gcodes are not supported.
    (Again, using the Post Processor for Mach3 ARC ATC from Aspire - Attached)
    35538
    Change the two "length" settings also. Divide them by 25 for a starting point.
    Is the current tool # changing on the run screen?
    Send me the UCCNC profile file (.pro).
    I'll look into it this evening. I haven't seen the tool change not working, and have not had any other reports of it.
    Jan 2008
    241
    Here's my profile.
    Thanks Gerry.
    Attached Files Attached Files
    35538
    In Settings > Function, set your tool Change Operation to Automatic Tool Changer.
    That should fix it.
    Jan 2008
    241
    I was bored
    Here is the complete run of that gcode.
    I just got the movie editor and not sure how it all works yet... just wanted to get this posted.
    https://youtu.be/XT4vYGeiWww
    35538
    Did you see my previous post?
    Jan 2008
    241
    Nope, didn't see it, but I swear I (think?!) I tried changing that before?!
    Another brain fart...
    Thanks Gerry, but we're not quite done yet LOL
    The tool change routine is working now...
    I think I still need to edit my PostP.
    - UCCNC still throws an errors about unknown gcode (I know, I can hide the warning, but I'd rather fix it then hide it)
    - At the completion of a toolpath, the spindle doesn't shut off.(No M5 at the end of the toolpath) - <FIXED>
    (I found and edited the PostP)
    Is there another checkbox I missed somewhere?
    Sorry for being a dumbass, and thanks for sorting me out!
    35538
    Try using this post.
    Jan 2008
    241
    K, as noted about, I got the PostP edited to add in the M5 on completion of the toolpath <-- Spindle now shuts off after the toolpath
    So now, I see, at the start of a new toolpath, the tool is zero'd, then raises Z to safeZ, then when
    moving across to the workpiece, Z slowly moves down on a slope towards the work.
    - Meaning I don't think its using the safeZ when moving back towards the work after a toolchange.
    So now, I need to figure out what gcodes are in my PostP which aren't supported by UCCNC.
    ... Just working out load here... Let me know if I'm making too much noise LOL
Page 1 of 2 12
  1. Replies: 76
    Last Post: 03-27-2023, 11:26 PM
  2. uccnc or mach3
    By eldons in forum UCCNC Control Software
    Last Post: 04-02-2017, 06:31 PM
  3. UCCNC and UC300ETH - A real scary speed monster.
    By A_Camera in forum UCCNC Control Software
    Last Post: 11-24-2016, 06:21 AM
  4. Mach3 plugin is now available for the UC300ETH
    Last Post: 11-11-2016, 09:45 AM
  5. UCCNC and Mach3 Modbus MPG?
    By Signal9 in forum UCCNC Control Software
    Last Post: 09-19-2015, 07:42 PM
