588,542 active members*
4,407 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > Hobbycnc controler question
    Jul 2004
    83
    I have read that some of you have built the hobbycnc controllers. I have built the 31v 4axis unit. Have a question for anyone who has built one. When it comes to installing the diode's, the kit comes with 15pcs(?) however
    it says do not install #15 on the board. 1 left over. Is this normal, was this intended to control perhaps the wire control from another version of this board. (wire cnc controller). Just seems odd that everything about this kit was exact, down to exact lengths of wire and then this extra diode. Just asking???
    So I finished it all up, did the 9volt test and all was well. I then loaded turbocnc on my computer, hooked up the controller and steppers. (no machine yet, just turning motors) -just to add - don't know much about gcode yet still learning- powered it all up, and launched turbocnc just wanted to jog
    the steppers a little to see something work. This is where it got strange. Steppers just advanced one step and didn't move again. I jogged in the software however no movement on the stepper. steppers were locked and warming up however they didn't move again. Shut it all down and tried again with the same results.
    I'm sure this is a stupid question, and i will regret asking it before i read some more, what am i doing wrong??
    thanks all
    35538
    They have a private support forum on Yahoo for their customers. I'd suggest joining it and asking there. Or emailing Dave.
    Jun 2004
    450
    did you set the step and direction pins in the motor configuration in turbocnc?
    Apr 2004
    210
    if you havent gotten it figured out yet, what you just described. It sounds like the sequence is off or the motor is wierd worng as in how each coil of the wire is energised. Remember the common wire is the +v wire not ground. The only way to make the common the common ground is to use a PNP transister to drive the curent in the backwords direction. You can identify the common coil with an 0hm meter, testing for the resistance. High impendance means they are the coil wires, any one wire that keeps the ohms at half resistance is the common. A good program to play with is FKEYBIT. you can set the parallel ports data I/O pins high or low and figur out what the sequence of the motors are. then re-write the step program in turbocnc i.e. xxxx1000xxxx, xxxx0100xxxx, xxxx0010xxxx, xxxx0001xxxx. This is only for phase driving though. If you have a step to phase converter then its your wireing job more likly!
    Remember half stepping would be 1000, 1100, 0100, 0110, 0010, 0011, 0001, 1001.
    each 1 stands for an energised winging in the stepping motor. you just have to figur out the order of it. Its easyer to change the 4 wires, then it is to rewrite the stepping program. There are also other parts to the setup like how many steps to an inch. Which you must convert to a desimal which turbocnc then converts to the proper movements. so say you had a screw which took 20 turns to make a nut move 1 inch. and you have a 100step motor. well doing whole stepping, that would be 0.0005 th. of an inch. or 100 steps per motor rotation X (times) 20 turns of the screw is 2000 steps per inch. now to turn that into a desamal you take 1 inch devided by 2000 steps per inch. which gives you 0.0005. If you where half stepping you'd get 0.00025 thousands of an inch per step. If you want to cheat on that last one its 0.0005 devided by 2 provided your using the same motor/setup every thing! or half of a half is a quorter !
    any question's hesatate to ask, its all right there.
  1. Diy Spindle Motor Controler
    By miljnor in forum CNC Machine Related Electronics
    Last Post: 11-06-2009, 05:01 PM
  2. Fanuc CNC controler
    By zekk_2 in forum Servo Motors / Drives
    Last Post: 02-27-2008, 08:46 AM
  3. Question to builders of HobbyCNC board
    By Catapultsup in forum Hobbycnc (Products)
    Last Post: 05-04-2005, 05:11 PM
  4. HobbyCNC 3 axis board build and review
    By Jay C in forum Hobbycnc (Products)
    Last Post: 02-19-2005, 05:22 AM
  5. DIY Electronics question
    By CNC Darren in forum Hobbycnc (Products)
    Last Post: 02-14-2005, 04:32 AM
