587,739 active members*
3,111 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Alarm when calling same tool. Fanuc 18i-m Mitsubishi M-V5Cn-L
Page 1 of 2 12
Results 1 to 20 of 21
    Hello everyone.
    We recently acquired a Mitsubishi M-V5Cn-L machining center with Fanuc 18i-m control, and can't seem to figure out how tool change works on it.
    Problem is whenever we try to call same tool that is already in the spindle, it throws an error "NO. 2058 Not Tool Command"
    So for example if my program finished with T01, and I try to call out "T01; M06" in the beginning of the program, it throws that error.
    Anyone has seem this happen on their machines? Any help will be appreciated.
    Re: Alarm when calling same tool. Fanuc 18i-m Mitsubishi M-V5Cn-L
    It's not unheard of to have a Fanuc control throw an error in this situation. I have an OMC that throws an error when the tool is already in the spindle. I have an 18MC that ignores it if I'm remembering correctly.
    There are many ways to work around this. If not using block delete anywhere in the program, add a block delete ahead of the tool change at the head of the program.
    Another way is to start with T1 in the spindle and do not program a tool change at the head of the program.
    Finally is to change to a blank tool at the end of the program so T1 is reloaded at the beginning of the program.
    The first two of these options leave a small window of potential for accidents if for some strange reason another tool is manually placed in the spindle between one run and the next. Depends on your operational procedures if this potential is worrisome or not.
    Not sure if there is a parameter to change this or not. I have a feeling it's a thing chosen by the machine builder. Look in your documentation for an answer to that.
    the_gentlegiant,
    Thank you for the reply. So at least now I know its not something fundamentally wrong with the machine.
    I have another Fanuc machine that will just ignore/skip thru redundant tool changes, so I was surprised that Mitsubishi would just alarm out.
    There's nothing in the documentation that mentions anything like that.
    I will try contacting Mitsubishi and see what they say about it.
    Quote Originally Posted by Micro-Swiss View Post
    the_gentlegiant,
    If you can post the ladder I might beable to tell you how to fix it
    drdos,
    Please see uploaded ladder I downloaded from my machine.
    Is this the file you were expecting?
    Thanks in advance.
    Attached Files Attached Files
    drdos,
    Thanks in advance.
    I don't see the attatchment
    drdos,
    I attached it as a .zip, not sure why it's not showing up.
    Let try again.
    Let me know if you see it this time.
    drdos,
    I'm posting thru industryarena. Are you on cnczone?
    I'm kind of confused why its showing up on both sites.
    Mar 2017
    314
    drdos,
    the zone and industry arena were the same forum, only skinned differently. Now you have to jump through hoops to see industry arena that you didnt have to in the past.
    You toolchange issue is in the way the MTB wrote the ladder. Believe it or not "it is a feature not a bug" is probably true.
    I am looking forward to see what DrDos does to change this behavior.
    I am in CNC Zone
    I found it on Industryarena. Is Keep Relay K4.5 on or off?
    drdos,
    Looks like Keep Relay K4.5 is off.
    Please see picture attached, to make sure I highlighted correct keep relay.
    drdos,
    Yes that is the correct bit. Try changing it to 1 and see what happens.
    DrDos,
    Good news, I tried changing Keep Relay K4.5 to 1 and it works now!! It simply goes right past redundant tool changes, no alarms. Just like my other Fanuc machines.
    Thank you so much for taking time to help us, really appreciate it.
    Would you be able to share with us what that Keep Relay K4.5 did? Is this keep relay only specific to this particular machine?
    Hopefully this information can be useful for other people with similar machine.
    Also, for some reason on Cnczone it shows that you posted a reply, but when I open a thread that reply is missing. I had to go to your profile account, and read your recent forum posts to find "Yes that is the correct bit. Try changing it to 1 and see what happens."
    K 4.5 is only used on your machine. What the builder did was give you the option to ignore the alarm if you called a tool that was already in the spindle.
    Sep 2012
    4
    Hi, I have the same problem on a Fanuc 0i-MB. Is there a way to fix it?
    Quote Originally Posted by agu View Post
    post your ladder and the alarm code
    Sep 2012
    4
    Quote Originally Posted by drdos View Post
    How can I extract the ladder?
    The alarm code is a combination of "cycle start lamp" and "lamp 2" that blink. On the manual this alarm is referred as "tool command error" with the description "the tool in the spindle is designated. Designate another tool".
    Try this
    Sep 2012
    4
    Try this
    Thanks, but the CNC is a very old 0-MC , there are no such functions.
Page 1 of 2 12
