587,311 active members*
3,586 visitors online*
Results 1 to 18 of 18
    Oct 2008
    34
    Dot matrix printer to vinyl cutting
    hi to every one
    i'v finished my second diy vinyl cutter with a dead dot matrix printer.
    any body interested can share info with me
    Oct 2008
    34
    more info
    no reply
    so
    here is more info and pics
    i made this with on old epson dot matrix printer.
    in commercial cutters the pressure of blade determine depth of cut, but here i used a future of this printers for this purpose :banana:
    in these printers u can set them for print multi layer paper (with stencil) by adjusting distance between printer head and lower roller, and what i have done is using this for adjusting depth of cut and if works nice
    Attached Thumbnails Attached Thumbnails 1.jpg   DSC_0013.jpg   DSC_0011.jpg   DSC_0012.jpg
    Nov 2010
    great
    Quote Originally Posted by bagherdn View Post
    no reply
    so
    great work, i want to know more detail about this, how about the blade? and how the blade move up and down?
    thank's,
    Oct 2008
    34
    blade
    down move is easily made by a solenoid and up move by a spring( these are done in mach3 as z axes control ) and blade holde is just ablade two miniator bearing and a steel tube as case with a adjusting screw,
    i'll upload more pics and info as soon as possible
    Nov 2010
    what solenoid do you use, DIY? can you show me the pict and detail information? i realy intrested to know what you have done. and in last picture there still using heatsink as in dot matrix needle head.
    sory for my bad english, hope you understand what i mean
    thanks
    Oct 2008
    34
    more info
    sory for my late answers, bec i'm very busy with my big project
    and here info:
    - about solenoid, it's came from an old dead copier machine some thing like below pic and about heatsink, because it become hot when working so i used the same al heatsink in the printer and cut through it for size of solenoid and fasten it with some screws, i drilled bottom of it for the head of cutter blade.
    - and for blade holder: i made like below pic(excuse me, but i draw it with corel bec i ' m busy )
    - u can see very good and nice info at: CNC, Sherline, Steppers, Servos, RC, Helicotpers, (don't forger here )
    i'm glad that one of my projects interested u, keep contact i'll be happy
    Attached Thumbnails Attached Thumbnails solenoid.jpg   blade holder schematic2.jpg
    Aug 2010
    72
    well done bagherdn thinking outside the circle
    trickey
    Dec 2014
    4
    hi to every one
    Well done dear.. i am also planing to make one , has every thing ready one simple qurey..how the rotary blade is controlled ? How the other two motors are controlled ? Whts the sw u r using to control the mc? Pls reply
  1. CNC Vinyl cutting
    By Darren_T in forum DIY CNC Router Table Machines
    Last Post: 10-01-2017, 05:54 PM
  2. Vinyl printer/cutter ???
    By Grindhouse101 in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 07-21-2016, 12:04 PM
  3. Vinyl cutting
    By ssutton in forum DIY CNC Router Table Machines
    Last Post: 12-04-2011, 09:06 PM
  4. Simple Printing on Vinyl with basic inkjet printer
    By FrmDstryr in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-23-2008, 03:15 AM
  5. Replies: 0
    Last Post: 05-17-2006, 04:46 PM
