587,671 active members*
3,377 visitors online*
Results 1 to 2 of 2
    May 2018
    5
    G0704 AW Vs. B Series Spindle Bearings
    I bought the NSK 7007AW bearing which is detailed here: https://en-mx.misumi-ec.com/vona2/de...ssuCode=7007AW
    But I now also see a lot of people are using the 7007B instead: https://uk.misumi-ec.com/vona2/detail/221000058233/?HissuCode=7007B
    The main differences are the Retainer/Holder type. The B is a momi removing and the AW is a punching. The other main difference is the contact angle, which on the B is 40 degrees and 30 degrees on the AW.
    Do these differences matter, or can we just use the bearings we already bought (the AW)?
    Aug 2016
    132
    Re: G0704 AW Vs. B Series Spindle Bearings
    They have the same load rating, so I can't see any reason not to try it.
  1. Going Cheap on Grizzly G0704 Bearings?
    By Atomic_ in forum Vertical Mill, Lathe Project Log
    Last Post: 06-07-2018, 11:42 PM
  2. Replaced G0704 spindle bearings
    By Semus in forum Benchtop Machines
    Last Post: 12-09-2015, 03:42 AM
  3. G0704 type spindle bearings for high speed.
    By ihavenofish in forum Benchtop Machines
    Last Post: 12-16-2012, 05:07 PM
  4. Replacing Bridgeport series 1 spindle bearings
    By A.A in forum Bridgeport / Hardinge Mills
    Last Post: 02-28-2009, 08:03 PM
  5. Series I spindle bearings
    By Jonne in forum Bridgeport / Hardinge Mills
    Last Post: 11-18-2007, 07:33 PM
