588,075 active members*
4,950 visitors online*
Results 1 to 16 of 16
    Apr 2015
    72
    Shunt Regulators
    Hey guys, I have an MX4660, and was told by leadshine that I should be using a shunt regulator. I am still waiting to hear back from them, but I was curious if any of you are currently using one? If so, what size/manufacture are you using? I am not familiar with shunts, I get their purpose but as for sizing one properly I am at a bit of a loss. Any suggestions or recommendations would be appreciated.
    Thanks,
    Ryan
    Nov 2012
    1273
    Re: Shunt Regulators
    What size motors are you using and what is the supply voltage? Judging by the word "benchtop" in the forum's title, I suspect you could get by without a shunt regulator.
    Apr 2015
    72
    Steppers are 906 and 570oz, power supply is 50 volts. Apparently when using an E-stop, there is some voltage/current being back fed? This has been known to kill drivers within the mx4660. They recommended a shunt regulator and a couple caps to prevent this.
    1943
    Quote Originally Posted by janz99 View Post
    The manual for the MX3660 shows a direct connection with no shunt regulator. They simply recommend using a power supply of 54V or less to account for back EMF from stepper deceleration.
    Nov 2009
    4415
    I run those same steppers on my G0704. I have run them with the MX3660? I did blow out a driver once (actually the SMD fuse). I always suspected it was due to me unplugging the drive before the power had dissipated.
    I haven't ever used shunts nor did anyone specify it. Not saying they don't. I was one of the first running that drive.
    A lazy man does it twice.
    Nov 2009
    4415
    Which is exactly how I have it powered.
    Does it show differently on the 4660? They are the same units basically just an extra drive.
    Apr 2015
    72
    This was Leadshines response when I had inquired about it: I sent him the link to the power supply that I had ordered.
    High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Prin
    "I recommend you to use a shunt regulate ,since the cap is not good for reducing back-emf value ."
    EDIT: I just found this documentation posted on this forum from Leadshine. Go to the second page of this thread:
    http://www.cnczone.com/forums/leadsh...estions-2.html
    On page 8 of this documentation it gives you a few shunt regulators that should be used.
    May 2013
    480
    so interestingly, their math is wrong.
    when calculating the additional energy dumped into a capacitor already charged to 48 volts, you must use the difference of squares to calculate the voltage its going to head to. so if 2 joules will charge your cap to 50 volts, if its already at 50, then it will charge it to about 67 volts.
    it would not surprise me if many have blown their drive because they had the E stop wired to disconnect the stepper driver from the power supply.
    Nov 2012
    1273
    Quote Originally Posted by Eldon_Joh View Post
    Strangely enough, I have seen people wiring their steppers through circuit breakers. Once I saw a really bizarre configuration where ONE of the stepper windings was wired through a breaker.
    Nov 2012
    1273
    By the way, what would be the "correct" way to E-stop a machine? Let's say we have a computer, a breakout board, a 48V power supply, 3 drives and 3 steppers.
    Dec 2003
    24220
    Quote Originally Posted by CitizenOfDreams View Post
    If you want a true E-stop then the correct way is a small hard wired control relay that has all the necessary stop functions in series or (N)AND'ed in its coil circuit, it is a combination of the selection of circuits on p6 p7 in this link.
    The items in the string would, of course be, apart from E-stop P.B.'s, any L.S. or the output of the a Mach charge pump etc, a contact on the control relay would switch any main contactor coil or power supply source that controlled motors.
    Everything else stays energized, just any motor driven or any device that can cause injury in the event of a machine failure etc.
    The charge pump also holds off any premature energization of the control relay until the P.C. has booted and the Mach Emergency reset.
    http://static.schneider-electric.us/...0140CT9201.pdf
    The only thing incorrect with the PDF circuits is that now it is a no-no to place the overload on the common or neutral side of the relay coil, if fitted, it should be in the main string.
    P.S: A contact on the control relay can also input a E-stop to inform Mach etc, that a external E-stop has taken place.
    Al.
    Albert E.
    Apr 2015
    72
    I believe with the 3660/4660 they have a specific e-stop output that you hook it up to. For machines without this, I'm not entirety sure what the correct way would be.
    1943
    An e stop that is wired such that it signals the computer controller to stop motion is in my opinion not a true emergency stop. I say this because it relies on software to stop the machine. A true e stop is independent and should stop all motion including the spindle.
    Having said the above, it is possible that the breakout board in the mx controller has a feature to disable the drivers, but even this is not what I would consider an e stop.
    The simplest e stop just cuts the incoming line voltage to the driver power supply, breakout board, and the spindle.
    You should never simply cut the power at a point between the power supply and driver, or between the driver and the stepper.
    Apr 2015
    72
    I think at this point, I am going to add the shunt regulator just to be on the safe side. I don't see it hindering the performance of the machine, and for $150, it will give me piece of mind. I emailed a few vendors and they have one of the 3 shunts that Leadshine has recommended in the documentation I linked above.
    Jan 2007
    235
    @janzz99
    Which Shunt regulator did you end up getting?
    Jan 2007
    235
    Quote Originally Posted by naspc View Post
    @janzz99
    I started some of my research. I ended getting one from advance Motion Controller SRST70.
    1. Advance Motion Controller SRST50 $100 + $9.36 shipping
    2. Advance Motion Controller SRST70 $100 + $9.36 shipping
    3. Called Leadshine talked to Chris Li, he said "either of the 2 (listed above) will do. They can be adjusted"
    4. Maxon motor DSR70/30 looks to be $399.98
  1. DC Voltage Regulators
    By kolias in forum CNC Machine Related Electronics
    Last Post: 05-05-2012, 10:49 PM
  2. Do you have to shunt a timer?
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 09-02-2011, 03:50 AM
  3. AMC B100A40AC and shunt
    By Karl_T in forum Servo Motors / Drives
    Last Post: 06-07-2011, 08:30 PM
  4. Shunt circuit
    By fahque99 in forum CNC Machine Related Electronics
    Last Post: 08-05-2009, 05:54 AM
  5. R Shunt Burn
    By wanchai101 in forum Servo Motors / Drives
    Last Post: 03-26-2007, 04:20 PM
