587,103 active members*
4,000 visitors online*
Results 1 to 8 of 8
    Oct 2007
    153
    what is a swiss screw machine ?
    I've seen a few ads for a swiss screw machine operator and I am curious, what exactly is a swiss screw machine ?
    Jul 2004
    601
    A screw machine keeps the tools close to the chuck, and moves the stock. Screw machines are great for long thin parts.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Oct 2007
    153
    Ahhhh....thank you- I am never comfortable having tools going near the chuck in a lathe
    Aug 2007
    135
    To avoid confusion, it's worth noting that only swiss screw machines move the stock. Regular screw machines do not.
    Quote Originally Posted by laszlozoltan View Post
    The tools do not move in Z - there's no way to crash them into the spindle. There's a small bushing that the stock goes through, and all the tools are arranged around that hole. On the other side of that wall is the spindle and headstock, which provides you Z movement.
    The Machinist's Chatroom
    http://machinechat.freehostia.com/
    Oct 2007
    153
    Quote Originally Posted by toastydeath View Post
    Thank-you I was refering to a conventional cnc lathe; theres the chance of making a mistake either programing or setting an offset wrong and end up with a tool holder going into a spinning chuck; it hasn't happened to me but I have heard of it happening at a shop where I once worked. I can see how a swiss screw machine could be a nice thing to have in a shop.
    Feb 2005
    303
    [ame="http://www.youtube.com/watch?v=QBFQBJhDNrc&feature=related"]This may help...[/ame]
    Good video showing moving stock / static tools.
    Feb 2005
    303
    Swiss machine != screw machine
    They're close, but not the same animal.
    Swiss machines are nice as dedicated machines for high-volume, high-precision, lights-out production, provided you're making parts < 32mm&#216;.
    But definitely requires a new mind-set if you're not used to it!
    Jan 2008
    136
    swiss machines were a range of small high speed cam auto machines developed in the clock and watch making industry. They were so good that the "Swiss" name stuck to that sort of machine type. Dont confuse "Swiss" for just being sliding headstock machines, they can be either fixed or sliding head.
  1. Predator hook up to swiss machine
    By tejano4life72 in forum CNC Swiss Screw Machines
    Last Post: 12-03-2007, 07:24 PM
  2. Spherical tip for machine screw
    By Fred Ming in forum MetalWork Discussion
    Last Post: 11-19-2007, 02:34 PM
  3. Knurling on a swiss machine
    By kazam07 in forum Uncategorised MetalWorking Machines
    Last Post: 07-31-2007, 04:54 AM
  4. screw machine in Victoria, BC
    By Roger N in forum Employment Opportunity
    Last Post: 01-11-2007, 07:40 AM
  5. screw machine?
    By pyroracing85 in forum MetalWork Discussion
    Last Post: 01-26-2005, 05:54 PM
