587,380 active members*
4,288 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Drift on 6090 with Weihong NK105 and Leadshine M552
Results 1 to 11 of 11
    May 2013
    20
    I just solved a problem that has been plaguing me for nearly 2 years so I thought I would share!
    My 6090 router from Jinan iTech has been slowly losing position in all axes, especially on complex jobs. This is most obvious in circles and arcs being non-concentric, and the Z height slowly dropping when doing engraving work.
    The solution was to set a jumper in each of the M542 stepper drivers to change the pulse logic to negative. The jumper is marked 'J1' and is in a little bank of 6 header pins, visible only by unplugging the driver then removing the plastic cover.
    Now it is fixed, I am pretty impressed by the accuracy and versatility of the machine - from ripping up slabs of plywood to engraving tiny details on PCBs.
    Background -
    The machine runs on a Weihong NK105G3 DSP, with 3 x Leadshine M542 stepper drivers. I use mainly ArtCam and also Eagle plus PCB-Gcode.
    I first noticed this effect particularly when using 'area clear' toolpaths on holes.
    I managed to contain the problem by switching to a finer micro-stepping resolution and avoiding area clear toolpaths, good enough for most work.
    But - I have been running some fine PCB work recently and accumulated errors of near 1mm were terminal!
    The error was repeatable - each time I ran the same job I would get the same result - but otherwise confounding as there was no obvious skipping, backlash or other failures I could see.
    Returning the machine to relative zero, would end up in a different position to where it started, even though the readout showed 0.000, 0.000.
    The technical bit -
    The DSP controls the stepper drivers through 2 pairs of control wires sending 'step' and 'direction'.
    There are a few different schemes but one variation is 'pulse logic' which can be positive, meaning that each step occurs as the voltage rises from 0 to 5V; or negative, meaning each step occurs as the voltage falls from 5V to 0.
    If you look in the NK105 manual on page 83 there is a diagram showing this - the section relates to a servo driver but this is a clue as to what the NK105 is outputting (note the manual says to choose # 2, single pulse stream negative logic).
    The M542s on the other hand are set to positive logic by default, at least mine came that way. Page 3 of the M542 manual sets this out.
    The repercussion of this is that every time there is a direction change, one micro-step gets counted in the wrong direction. On a complex job, this adds up to a visible error.
    Those area clears involved lots of little concentric circles and therefore lots of direction changes!
    Jun 2016
    51
    Re: Drift on 6090 with Weihong NK105 and Leadshine M552
    We are looking at getting a CNC with a Weihong NK105G3 DSP controller. Do you have a post processor for it that might work with Inventor HSM? do you know if there is one available?
    MarryU Guest
    Generally NK105 G2 or G3 are DSP offline terminal used to control each axis,not the software for making G code,so it has no post processor acturally. You need to look for post processor of HSM.
    Mary
    falacncrouter Guest
    There is a little different between Weihong NK105 G2 and Weihong NK105 G3. I think you would better to ask CNC Router manufacturer from which you bought it.
    Jun 2016
    51
    Thanks Mary, but Inventor / HSM needs a post-processor to work with NK105 G2 or G3 right? Do you work with Weihong?
    MarryU Guest
    You welcome Lael, yes I confirm with their technicion,they dont have.
    May 2017
    Hi
    I have exactly the same problem with Weihong NK105 and Leadshine MA860H
    Can you please tell me how exactly should I change "J1" jumper pulse logic?
    Thank you in advance
    May 2013
    20
    Hi Archil
    Well it has been a year or so but I just found your message. Did you ever solve this problem?
    Looking at the ma860h manual it looks like you need to add a jumper to J3 in your case to achieve the same setting change (active at falling edge)
    See page 4 http://www.leadshine.com/UploadFile/Down/MA860Hm.pdf
    Quote Originally Posted by Archil View Post
    Hi
    Apr 2006
    512
    I am having problems on the Y axis drifting(see attached). Can you show how you cured the problem?
    Mine is Weihong NK105G2. I having a problem with the spindle gears. When turning on the spindle the the inverter reads the following when cycling through the gears:-
    Gear Inverter
    0 0
    1 150
    2 320
    3 470
    4 0
    5 150
    6 320
    7 470Attachment 361974
    May 2013
    20
    Hi bigz
    Well better a year later than never did you ever solve your problems? The drift you show here is a lot more severe than what I was experiencing so it might be a different issue,
    The spindle gear problem however - I also had but fixed. The cause is that the 3 wires from the NK105 to the vfd for speed control were connected incorrectly. These are marked S_0, S_1 and S_2 and need to connect to corresponding lines on the VFD (markings will depend on your model of VFD).
    I hope this gives you a clue!
    Quote Originally Posted by bigz1 View Post
    Gear Inverter
    0 0
    1 150
    2 320
    3 470
    4 0
    5 150
    6 320
    Apr 2006
    512
    Hi Loska
    Thanks I fixed the drift with your method. I will have a look at the inverter thanks.
    Have you had any luck wih 4th axis?
    Happy New Years
  1. About DSP NK105 controller
    By linda_roctech in forum Roctech CNC Routers
    Last Post: 10-30-2022, 06:32 PM
  2. Tool Measure nk105 Weihong
    By electracks in forum Chinese Machines
    Last Post: 08-06-2019, 09:34 PM
  3. Post processor for Weihong NK105
    By Chop3d in forum Chinese Machines
    Last Post: 11-19-2014, 06:47 PM
  4. Question on the menu panel WEIHONG NK105 g2
    By andu in forum Machinery Manuals / Brochures
    Last Post: 04-19-2013, 01:38 PM
  5. Nk105 G2 User manual
    By AmicX in forum Machinery Manuals / Brochures
    Last Post: 08-10-2012, 11:18 AM
