587,638 active members*
4,510 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need help opening a .LAD file with Fanuc Ladder III.
Results 1 to 20 of 20
    Feb 2005
    19
    Hi guys,
    I'm having a problem opening a .LAD file that was extracted from a 32i Model B control. Fanuc Ladder III v5.7 keep saying PMC type is not supported.
    The machine is a Eurotech 735sl Y that was built approx. around 2012. I saved the back to a USB drive from the control and named it 1000.LAD.
    Any help is much appreciated. Thanks in advance.
    Dec 2009
    970
    Re: Need help opening a .LAD file with Fanuc Ladder III.
    The last version is 7.3
    Feb 2005
    19
    Quote Originally Posted by zavateandu View Post
    Thanks for the response. Looks like I need to update. Lol
    Call Fanuc it is only $21.00 to upgrade
    Feb 2005
    19
    Update: So I have updated to the newest Ladder 3 and can successfully import the backup from the memory card, but it is asking me for a password that I do not know. Hmmmmmm, what to do now. Not sure if I should contact the MTB to see if they will give me the password or if it is a fanuc thing.
    Dec 2009
    970
    it is a MTB password,Fanuc will not give it to you
    you can view it on machine but can not edit it.
    on the machine you will need also a password to open it
    Feb 2005
    19
    The password on the machine to view it is "L". Are there 2 different passwords, 1 to view and 1 to edit. Sorry for all of the newbie questions, I'm learning as we go. LOL
    Nov 2014
    please send us ur machine pmc ladder file then i send u password definately
    Nov 2014
    my email id is [email protected]
    Feb 2009
    6028
    Yes, there are two, one for ladder troubleshooting and on for editing. Good luck.
    Oct 2012
    3
    Still needs help?
    I think I can help you with the password
    Feb 2005
    19
    Quote Originally Posted by Magulyy View Post
    Still needs help?
    Should I PM you?
    Oct 2012
    3
    Send me an email with the ladder I check the password for you
    [email protected]
    Jul 2014
    222
    hi guys, I have downloaded ladder file from machine (fanuc 16m) to my laptop via RS232 serial link to a NC file using CIMCO editor. Now I have Fancu ladder III and in that program I need to have .lad file, I have tried renaming .NC to .LAD and tried opening it in Ladder III but no luck, I have also tried TOOL-Data conversion and selecting NC file and convert it to LAD file there, no luck too, says "PROGRAM NAME ERROR".
    What to do with this NC file from machine in which LADDER have been downloaded to read them in FANUC LADDER III?
    Thanks in advance
    If you attach the file I can tell you. You can try to create a dummy ladder using the same PMC type. You will have to have END1 and END2 in your dummy ladder. Them complile it. Now goto File and IMPORT your file as a Handy File
    Jul 2014
    222
    heres nc file with ladder attached
    Quote Originally Posted by drdos View Post
    It is a Handy File. You can open it with Wordpad and delete the first bit of garbage. You need everything : and beyound. (&FWLAD)<---delete :S004000000FB
    Also it said that it has a password, do you by chance have the password? Also what is the PMC type?
    Jul 2014
    222
    do you mean nc file should start like this:
    S22428000000040000000000005AA500000000000000000000 000000000007000000000000A9
    S22428002000080000FF2F0000BBE1FFFF0000000000300000 751300007C190100160000005F
    or like this:
    :S004000000FB
    I tried both versions, no luck.
    Where do you see it is password protected?
    I don't know password, where to find it?
    What is PMC type, is it type of machine, if yes it is Stama Robodrill Alpha T10B with Fanuc 16-M on it.
    The mainboard designation number is A16B-3200-0010 and manual for that is here:
    http://www.repmatel.es/directorio/Ma...NUC/62445e.pdf
    edit:
    Seems like that control is PMC type SB3 according to fanuc ladder 3 manual. Is that correct?
  1. Fanuc 6T PC model B ROM file to ladder
    By tuanpq in forum Fanuc
    Last Post: 07-22-2020, 11:40 PM
  2. Need Fanuc 0M-B Ladder File
    By Third-Gen in forum Fanuc
    Last Post: 10-03-2015, 05:22 PM
  3. Replies: 13
    Last Post: 02-05-2014, 04:05 PM
  4. stp file not opening
    By Forrest C in forum Solidworks
    Last Post: 01-20-2013, 04:42 PM
  5. Opening a .dwg file ??
    By AirChunk in forum BobCad-Cam
    Last Post: 09-22-2010, 02:35 AM
