587,326 active members*
3,475 visitors online*
Thread: Okuma VMC
Results 1 to 11 of 11
    Dec 2006
    310
    Okuma VMC
    Dear Experts
    We have Okuma VMCs of Models MB56VBR;MA650-VBR;MILLAC 4VA
    Request to share signal details or addresses to check issues related to Cycle Start, Feedhold etc
    Additionally if other technical/maintenance details may also please be shared
    Regards
    Jun 2015
    4156
    Re: Okuma VMC
    hy, pls check attached osp300pdf's, about using "osp io monitor.exe" ( located on right toolbar ) :
    ... VIRD[1210]=1 means door is close
    ... VORD[16]=1 means that machine is in lock mode
    * examples are for lathes, but mills share same osp, so there are similarities
    different machines have different signal maps
    you can check status for single block, block skip, override value ( for example you can check if override is between 80 and 120% ), monitoring, coolant, etc / kindly
    ps : if you wish to see what others have done, then search for vird & vord on the forum; i believe that maybe also vdin & vdout can be used, but i don't have experience with those
    Attached Files Attached Files
    Dec 2006
    310
    Re: Okuma VMC
    Thank you so much, shall check in the machine once we resume
    Dec 2006
    310
    Re: Okuma VMC
    Thanks for sharing pdf
    Today we could correlate few points out of the pdf
    Request your suggestion for the following as we are just not familiar with OKUMA CNC and PLC :
    1. Error 4717 alarm D Door condition unusual 1 in Okuma OSP P200MR with D300 win MA2 013A PLC
    Help screen indicates
    ATC = Magazine Door
    ATC1 = 1st Magazine Door
    ATC2 = 2nd Magazine Door
    ATC3 = 3rd Magazine Door
    ATC4 = 4th Magazine Door
    APC = APC setup door
    Door = Operation door
    Pl revert if all 7 signals mentioned above are ANDed in PLC and error comes if any of the 7 signals go low - if yes, please let us know how to search these addresses related to Door under I/O monitor as Label to search is unclear
    Output QX0534.1 under PLC monitor is off ie 0
    Can u please tell on how to check condtionons to satisy this output QX0534.1 under PLC Monitor
    We are finding Libraries, data type, logical POUsand physical hardware on left hand side
    2. Also if u can please explain meaning and usage of Change mode PLC control mode, spec mode, PLC spec mode etc under Display change
    Warm Regards
    Apr 2020
    36
    Re: Okuma VMC
    H Rishikesh
    Please attach a photo of the screen with an error.
    And I will try to explain to you
    Jun 2015
    4156
    Re: Okuma VMC
    hy rishikesh
    try "IF [ VORD [ 0221 ] EQ 1 ] "
    look not only at "label" but also at "comment"; you have to check each item, since is not possible to search in all fields at once ( at least i could not do it )
    if you get tired of this method, then you may check all displayed items at once, by opening/closing the door from the panel, and looking at the screen, so to find which item is changing color : so you have to toogle the signal, and look at the item that is flasing on screen; this method allows to check 15-20 items at once
    searching may take a while ... be patient, search only 5minutes each day, etc try asking your okuma dealer about those, maybe you are lucky
    enabling/disabling acces to the possibility of forcing signals and/or using a mask
    ... if it is disabled, then you can only check the values
    ... if it is enabled, then you can also change the values, and use a mask to force permanent signal states ( for example to have a faulty equipment to output an "ok" signal, so you could continue machining until service team will arrive )
    in most cases, it is enabled when new hardware is installed, or when cnc is delivered, or during remote service sessions, etc
    i have also seen those areas(like a highlighted matrix), but so far i have never needed to change something there
    i guess that is like a map that shares same info like the management data card
    Front door lock &operator door close were not coming together hence output for front door close was not getting ON, we could resolve the issue
    please, if i may, how did you fixed it ?
    i have seen big doors erroring out during machining ... too heavy for the small locks / kindly
    Dec 2006
    310
    Re: Okuma VMC
    Thanks you for your detailed response
    In another similar machine, we found inputs for Front door lock and operator door close were coming together but not in this one, hence adjusted switch a little then started getting both inputs hence with M32, output got on
    We feel all 7 inputs of various doors are ANDed in logic - whether our understanding is right?
    We tried to reach out to local Okuma but to no avail, hence took about 4 hours to fix this issue
    As informed u earlier, we dont have any prior knowledge on Okuma, although we have worked in Fanuc and Siemens hence sorry for asking u very basic things as below :
    1. "IF [ VORD [ 0221 ] EQ 1 ] - where to type this IF statement and what is the meaning of this IF statement to understand correlation with output QX0534.1
    Dec 2006
    310
    Re: Okuma VMC
    Thanks for your response
    Two inputs viz Front door lock &operator door close were not coming together hence output for front door close was not getting ON, we could resolve the issue
    If u can please respond to other queries mentioned above
    Regards
    Apr 2020
    36
    Re: Okuma VMC
    I can assume that this is an operator door error
    An electromagnet is installed in the lock and there is no confirmation of its unlocking
    iFDCL-Door Close confirm
    iDRRP-Door Lock Pin ON Confirm
    You can watch them relays in the POS unit usually fail
    Provided that you have checked and adjusted the operator door locks
    Dec 2006
    310
    Re: Okuma VMC
    Thanks you for your response
    We feel all 7 inputs of various doors are ANDed in logic then please let me know how u thought it to be only due to operator door?
    Thank you once again
  1. Replies: 0
    Last Post: 01-07-2019, 04:49 AM
  2. Replies: 0
    Last Post: 04-21-2018, 06:23 AM
  3. Replies: 4
    Last Post: 10-05-2014, 04:14 PM
  4. Replies: 4
    Last Post: 10-02-2014, 04:58 AM
  5. Replies: 1
    Last Post: 08-28-2008, 02:09 PM
