588,445 active members*
4,987 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Sending Program Files
    Apr 2009
    8
    I need to back up all my Hurco files...HD3 files, but I don't want to load them onto a diskette and then load them onto my laptop. Is there a way to load them using the Upload/Download function and an RS232 cable. I was able to get my hurco to send the file to my laptop, into an editor (Cimco) But I can't send it back to the hurco. I file that came thru was just a bunch of symbols and numbers...Do I need to save the file as a certain type of file? Or is there a program I need on my laptop to read HD3 files?
    Thanks,
    Eric
    May 2005
    117
    HD3 files are binary so they must be handled differently to gcode text files. I wouldn't trust the ones you've transferred already to be good copies either, I hope you haven't deleted them off the machine already...
    I used to have a dos based up/downloader for HD3 files that worked well, but I haven't really used conversational for a long time so I don't have it anymore.
    I think this is it, but I'm not sure, you'll have to try it and see.
    I'm not sure how that'll behave in vista, but I used to use it in xp successfully by changing some of the compatability settings.
    Nov 2006
    382
    I use cute ftp to and a cat 5 cable and it all goes back and forth well. You have to have the network option. Cute ftp I thing is freeware with a timebomb to buy it. I can not remember for sure. Ours is full functioning and we bought the package. Hopes this helps.
    Jetski (alias Tooling and Engineering Czar)
    "I may not have the keys to success.. but I have learned to pick the locks"
    Apr 2009
    4
    Hyperterminal
    Quote Originally Posted by Astrocncdept View Post
    Thanks,
    Eric
    go to programs
    accessories
    communications
    Hyperterminal
    set a name , like a machine name then say O.K.
    now it will ask for a port com 1 or two you may need to change it to the one your using , set your port settings the same as the machine , after you have it set up call Hurco to get all your setting and they can help you set up the rest
  1. Problems sending files to Prototrak MX2
    By Lugy in forum Dolphin CAD/CAM
    Last Post: 03-03-2016, 05:08 PM
  2. SENDING PROGRAM FROM MCX TO OKUMA OSP U10M
    By ZeroDay in forum Mastercam
    Last Post: 08-11-2008, 04:50 AM
  3. Sending Program ...
    By politecnica in forum Fanuc
    Last Post: 03-05-2008, 01:28 PM
  4. Control Oi not receiving end not sending a program
    By avaitsis in forum DNC Problems and Solutions
    Last Post: 07-23-2007, 09:43 PM
  5. Mazatrol M-32 control on H630N sending program
    By CHRIS-CNC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 03:43 AM
