588,525 active members*
4,947 visitors online*
Results 1 to 2 of 2
    Mar 2007
    75
    Wing cutter in the Netherlands
    I've built a CNC wood mill once, but it has been dismantled after proving too big for the shed in the new house... I still have the computer, drivers, power supply, motors, etc. I've even bought a 4th motor recently, because I would like to build a foam wing cutter. I am going to build something like the Dray Construction Plans, scaling them to my own prefered dimensions. I have some questions:
    1) Is cutting a 1,3 meter wing in one piece too big?
    2) If it is not, does it require a lot of wire tension?
    3) If so, how much?
    I still have Mach3 on an old PC in the shed, I hope that will do the trick. What software do I need to create a cuttable file from DWG / DXF files?
    Thanks,
    Hugo
    Jun 2009
    251
    I have built a 2x1x1 meter foam cutter and it works perfectly, it cuts the 2 m wide side of foam in one pass at a lover speed, around 30 cm/m depending on the type of foam but i have learned that i needed a thicker wire, i think about 0.8mm dia. since the thinner wire was cutting at half that speed.
    Will post pictures as soon as i can take them, i don't have a single picture of it because the camera on my nokia N900 is very bad at anything short of a blazing sun for light.
  1. ExcelCut 4 Axis Wing Cutter with Source Code
    By arman in forum CNC Wire Foam Cutter Machines
    Last Post: 03-22-2018, 07:14 PM
  2. Greetings from the Netherlands
    By kboensma in forum European Club House
    Last Post: 01-07-2009, 11:10 AM
  3. CNC Foam cutter for RC plan wing
    By jc de campo in forum CNC Wire Foam Cutter Machines
    Last Post: 12-08-2008, 01:21 PM
  4. Hi from the Netherlands
    By jeroen87 in forum European Club House
    Last Post: 08-11-2008, 11:51 AM
  5. One out of 18mm MDF in the Netherlands
    By Witsenburg in forum CNC Wood Router Project Log
    Last Post: 07-08-2007, 08:20 PM
