588,205 active members*
4,618 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > GCode Simulator for Hobbiest?
    Feb 2013
    Short Version of Question
    I am pretty confident that I can write the g-code to make the parts I want to make. However, I would like to have some sort of check on my newbie tool-path before I waste my friend's time on his CNC machine. I have not had much luck finding a software tool to use to visualize the tool-path.
    What is the most affordable option for hobbyists wanting to visualize a g-code toolpath?
    OpenSCAM looks like it was supposed to be exactly what I want. Unfortunately it crashes every time I edit the tools or save a project.
    Back Story In Case it Helps
    I am very very new to CNC and I know that I probably don't even know the correct questions to ask. So here is the context of my question in case it helps.
    I am hoping to build or buy a CNC router next year. I can just barely afford a machine but cannot afford to spend lots of money on software too. I definitely cannot afford the CAM software my friends use on their CNC router (costs $1K+). So I am trying to do a proof-of-concept that I can do an end to end workflow from idea to design to gcode to cutting.
    I've looked at some of the affordable CAM software packages. The parts I am cutting have a number of tool changes for different types of surfaces but the patterns are all nice strait lines or circles. Quite frankly I am fairly confident it will be easier to just hand write the gcode than to duplicate the design in the CAM software after designing it in CAD; even after allowing for finishing passes, etc. the commercial CAM packages seem to add very little value for my application... except they allow you to visualize the generated tool path.
    Jan 2006
    2985
    There are lots of free CAM options, I'm not the one to talk about them. If you programs are simple enough that you can easily write them by hand, I'd think it would be easy enough to check your work by hand as well to make sure what you did makes sense.
    Jul 2003
    196
    Try this: Untitled Page
    jgro
    http://jgroshoppages.blogspot.com/
    May 2008
    266
    NC Corrector NC Corrector, free G-Code editor.
    Martin.
  1. mentor or hobbiest in NE Mississippi
    By msbr in forum Mentors & Apprentice Locator
    Last Post: 04-02-2013, 09:56 PM
  2. nooby hobbiest
    By crossleymarko in forum WoodWorking Topics
    Last Post: 03-16-2012, 01:02 AM
  3. Hobbiest CNC: question about chinese ebay system
    By Matt Clara in forum Commercial CNC Wood Routers
    Last Post: 05-03-2010, 02:32 PM
  4. Coolant Recommendation for a hobbiest
    By apeman88 in forum Tormach Personal CNC Mill
    Last Post: 01-29-2008, 06:04 AM
