588,112 active members*
5,272 visitors online*
Results 1 to 9 of 9
    Sep 2007
    740
    Limit switches
    I have a hobbyCNC board. It is supposed to have pullup resistors on the input pins. I have my limit switches wired in series and when I use the auto configure in Mach3, it sees each switch as it is tripped. If I leave the switches in the config, Mach3 says a limit switch is tripped as soon as I turn it on.
    What to do?
    I am thinking I need to add an additional resistor.
    May 2006
    1469
    Because the pins have a pullup resistor already on them that means that the pin or input is high when at rest.
    The normal way to wire your limit switches is normally closed (NC) between the input pin and ground. That brings the input or pin low when a limit switch is not activated.
    Then when a switch is activated, (a limit is reached) then the switch opens and the input returns to high.
    In "Ports and Pins" set the relevant input to active high. In other words leave it crossed in the active low column.
    Hope that's clear.
    Greg
    Sep 2007
    740
    Thanks Greg.
    That is the way it is setup, but Mach thinks it is active when it is not. There is a selection in the ports and pins setup to do this automatically. If I use that Mach sees me trip each switch and sets the config just as you said, but as soon as I save that into the config, it says I have a limit switch triggered, when I don't.
    Is there some other setting I need?
    May 2006
    1469
    On the diagnostics page is the LED lit for each of the limits? LED lit means it is active.
    They should not be active until you activate a switch.
    If they are not lit then it sounds like electrical "Noise" is triggering the Estop condition.
    Then enter about 2000 in the "Debounce Interval" on General Config and see if that stops it.
    Greg
    Sep 2007
    740
    Thanks Greg,
    The debounce fixes it almost. It now works for about 5 minutes or so and then it triggers again sometimes. Would increasing or decreasing the number help?
    What common sources of noise could do this?
    Motor wiring is shielded, and some of the limit switch wiring is as well. Maybe I need to rewire limits with all shielded.
    May 2006
    1469
    Yeah take it up to 3000 and see if that stops it.
    I personally prefer to overcome noise with strategically placed capacitors but as this is only limits then a high software debounce should be fine.
    Sometimes simply having some physical separation of signal and motor wiring can make the difference. For example they may share one conduit.
    Greg
    Mar 2008
    3655
    Hi Corrie! You can't assume that the colors mean anything. Use a volt-ohmeter to find continuity between the wires. Three wires probably means you have BOTH normally open AND normally closed contacts. The two wires that read continuity with the switch at rest are normally closed and would be the wires to use as limit switches. One of the those two wires will also show continuity with the extra wire when the switch is activated. THAT wire will be your common wire and the last wire will be the normally open "home" switch.
    I hope this is helpful to you.
    CR.
    Apr 2004
    297
    Thanks for the response, I did check for continuity but not in the way you suggest. I kinda get what you are saying though, I will try agian,thanks.
  1. Limit switches and homing switches
    By AeroKam in forum Open Source CNC Machine Designs
    Last Post: 01-05-2008, 02:56 PM
  2. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  3. Limit switches and home switches
    By viktorcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2004, 12:11 PM
  4. Limit switches
    By Phoenix-MN in forum DIY CNC Router Table Machines
    Last Post: 04-14-2004, 07:16 PM
  5. Home switches and limit switches.
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 04-08-2004, 11:32 PM
