Hi
Can anyone supply me with details on how to change the ladder on fanuc control.I usually work on mazatrol which the outputs can be forced and i believe can only be done on the fanuc by changing the ladder.
Hi
what is the type of your fanuc control?
Fanuc 0,fanuc 10,fanuc 18,etc?
sorry about that its an 18M.
for fanuc 18m,you can edit plc ladder direct from pc to use fanuc ladder iii software trough rs232 port,or memory card
you can download it from
Fanuc Ladder III v4.6 - Sonsivri
good luck!
thanks for your help mate.
if its just a 18 (not 18m-b or 18m-c) it uses eprom, requires a editing module and a 1m rom adapter for the pcwriter- I think...Ive got to do one right now, just looking for the hardware. if the title page says pmc software is RA2 or SA2, I think it takes more than toggling the edit bit in K17.
Tim
Hi Tim,
It's a bit long since last reply but I just try my luck.
I have a Nakumura Tome TMC 20II lathe machine, controlled by Fanuc Series 18T, PMC type RA2. Ladder III do not apply to this PMC type.
The machine is really old and I can only find limited information online. I lost my ladder programming and now wish to re-install back. I don't have the TMC20II ladder diagram but I am ordering a hard copy TMC15 diagram, which I guess need some modification.
Can you briefly guide?
Thanks in advance.
Fam
