588,487 active members*
6,266 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > I have a huanyang hy02d211b VFD . 110 VAC water cooled spindle
Page 1 of 2 12
Results 1 to 20 of 42
    May 2016
    27
    It is rated for 24,000 rpm. I cannot achieve more 7,999 rpm any suggestions?
    Any Help is appreciated
    When running HZ registers 133.33 It is set to 400 hz 1.7 Amps
    15362
    Re: I have a huanyang hy02d211b VFD . 110 VAC water cooled spindle
    Quote Originally Posted by mpresti8 View Post
    1.7Ax3=5.1A at the spindle 8.8A at the supply.
    You did not say what spindle you have; it sounds like your Parameters are not set correctly.
    How many Amps is your AC supply??
    Mactec54
    May 2016
    27
    20 Amp circut
    This unit was running at Max revolution until this happened
    15362
    20 Amp circut
    Until what happened, did it overload or stall, is this being used from the KeyPad or by remote 0-10v??
    Mactec54
    May 2016
    27
    Run by the keypad on the front of the inverter no problems other than I wanted to slow it down because I believe it was running too fast for the surfacing blade i had on it. I was checking settings and the VI VR pin that you move the jumper on to change from the keypad operation to the Mach 3 software operation That is when i could not get it to work properly at this time it is shorted across the VR pins
    Did you check if this Parameter PD144: Max Motor RPM is set to 3000
    https://www.automationtechnologiesin...5-110vac-input
    May 2016
    27
    PD144 = 3000
    May 2016
    27
    Quote Originally Posted by automationtechinc View Post
    PD144 is set to 3000
    May 2016
    27
    I have the GDZ-80-1.5B 24000 rpm 1.5 KW 110V 400Hz 5ASpindle water cooled
    May 2016
    27
    let me check that real fast
    PD144 = 3000
    15362
    PD144 = 3000
    This Parameter PD144 is related to the Max RPM only.
    This is the Parameters you need for KeyPad / Pot use.
    Pot Control
    PD001=0
    PD002=1
    PD070=1
    JI Jumper 2-3=VI Position. You can try either position as some of these drives can be either for Pot use, these Parameters are important as well to make it run also for Pot control
    Mactec54
    May 2016
    27
    Pot Control
    PD001=0
    PD002=1
    PD070=1
    Those settings are correct still no luck
    15362
    Check the Jumper is not damaged.
    What are the Parameters you have set in the Drive
    Mactec54
    May 2016
    27
    Curent settings are as follows
    PD001=0
    PD002=0
    PD003=400
    PD005=400
    PD004=400
    PD007=.0.50
    PD009=15
    PD010=8
    PD011=133.33
    PD013=8 FACTORY RESET
    PD014=10
    PD015=10
    PD025=1
    PD027=0.80
    PD141=110
    PD142=5
    PD143=2
    PD144=3000
    Jumper is fine
    May 2016
    27
    I am running from the VFD not the computer or Mach 3
    Honestly this thing is driving me nuts.. One thing that I have seen on these YouTube videos is that when they change a value and press set the screen displays END mine does not display that
    Give me a call, I will help you to check to find the problem
    The phone number is on our website:
    https://www.automationtechnologiesin...ucts-page/vfds
    May 2016
    27
    Here are the settings that work
    PD00=0
    PD001=0
    PD002=0
    PD003=230
    PD005=400
    PD004=400
    PD006=2.5
    PD007=.0.20
    PD009=15
    PD010=8
    PD011=120
    PD014=10
    PD015=112
    PD025=1
    PD027=0.80
    PD141=120
    PD142=5
    PD143=2
    PD144=2600
    15362
    PD00=0
    PD001=0
    PD002=0
    PD003=230
    PD005=400
    PD004=400
    PD006=2.5
    PD007=.0.20
    PD009=15
    PD010=8
    PD011=120
    PD014=10
    PD015=112
    PD025=1
    PD027=0.80
    PD141=120
    PD142=5
    PD143=2
    PD144=2600
    PD003=230 this is what the KeyPad uses for the spindle speed, having it at 230 will only give you just over half max RPM from the Keypad.
    PD015=112 Deceleration This is ridiculous, this is giving the spindle 112 seconds to stop most use 3 to 8 seconds
    PD144=3000 this needs to be 3000 this unlocks the Drive to give you max RPM of 24,000 RPM
    I guess you did a Reset because there is nothing special about these settings, I'm sure if this is working correctly, you are going to have some trouble down the road, you sure you have a genuine HY VFD Drive
    John should be not giving people these numbers as they are incorrect
    Mactec54
    May 2016
    27
    Mactec54 thank you for your help as well. JOHN did not give me incorrect information .I made the mistake of typing the settings in incorrectly. I do not think it is your place to chastise John for helping me. I made the mistake not him and you probably should apologize to him. Everyone here is trying to help each other not belittle one another
    Mike
    I think there are some type errors.
    PD003=230 should be 400
    PD015=12
    PD144 can be 3000 (Max 24000 rpm), If you use PD 144 = 2600, your max speed will be less than 24000 rpm
    We sold many VFDs and We helped many people to set up
    https://www.automationtechnologiesin.../vfds/kl-vfd22
    I helped many hobby for free, I did not never give any one incorrect information
Page 1 of 2 12
