588,093 active members*
4,501 visitors online*
Results 1 to 7 of 7
    Feb 2013
    81
    Thermal Dynamics Cutmaster cut height question
    I have a little Thermal Dynamics Cutmaster 38 with a 30amp drag tip. I use a floating head without THC set to zero at each cut.
    What height off the material should the pierce height and the cut height be?
    May 2006
    1469
    Re: Thermal Dynamics Cutmaster cut height question
    Don't have an answer for you.
    Just curious, will it establish an arc if the tip is above and not touching the material?
    Jan 2008
    2247
    Refer to your operators manual for the cutmaster for correct cut height. Most likely it is somewhere between .06" and .120".....depending on the consumables you are using.
    Jim Colt Hypertherm
    Quote Originally Posted by marbles View Post
    Mar 2004
    93
    I would say on .190 mild steel, .1500 Pierce height, and a .1200 cut height would be correct.(about max pierce) Same with settings on .135. 16 ga. you could drop down even more..
    Feb 2013
    81
    Quote Originally Posted by Scott V View Post
    Thanks for thoughts. Interesting to see your settings.
    My current settings on 3mm (16ga.) mild steel
    pierce height of 8mm
    cut height of 1mm
    These settings are somewhat arbitrary though, I guess i was trying to emulate the drag cut idea without actually touching the steel.
    Interesting to see the standoff you suggest and how close your piece and cut height are. I'll try your setting and see how that works.
    Just out of interest whats your pierce delay and feed rate on 16ga. ?
    Aug 2015
    9
    Here is a copy of a manual sent to me from TD support.. it has cut charts that you can use... Its for the Cutmaster A40 which would be close to your TD 38
    http://victortechnologies.com/IM_Upl...453_0-4978.pdf
    Feb 2013
    81
    Quote Originally Posted by knock10090 View Post
    Thanks for this. I just read through the A40 manual for the cut and pierce heights. It gives a cut height of 3.56mm. Just out of interest I checked the Cutmaster 10 manual, which has the same 30A max as mine. It states 'For standoff cutting, hold the torch 1/8 - 3/8 in (3-9 mm)' Further down in the material and feed speed it states the standoff as between 0-1.6mm?
    I'll need to write to them, no point in blowing out more tips..
  1. thermal dynamics cutmaster 51 help
    By ringomike in forum Waterjet General Topics
    Last Post: 01-29-2016, 06:19 AM
  2. Considering Thermal Dynamics Cutmaster 42
    By chasxjs in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-15-2014, 10:47 PM
  3. Thermal Dynamics Cutmaster A80
    By Flyinfarmer in forum Waterjet General Topics
    Last Post: 02-20-2010, 04:01 PM
  4. Thermal Dynamics cutmaster 101
    By SybleK in forum News Announcements
    Last Post: 01-15-2009, 11:20 PM
  5. Thermal Dynamics Cutmaster 101
    By tuknrm in forum Waterjet General Topics
    Last Post: 11-19-2006, 10:52 PM
