587,158 active members*
3,048 visitors online*
Results 1 to 6 of 6
    Feb 2016
    13
    Set starting point for tool?
    Using solidcam, I set the origin to the center of my part, How to I set the starting point of my tool so it doesn't start inside the part and move to starting position.
    Im using solidcam16 and mach3
    Oct 2013
    64
    Re: Set starting point for tool?
    You can pick toolpath.
    Sent from my Nexus 5 using Tapatalk
    Feb 2016
    13
    Thank you for your time... New to 4 axis, and solidcam, trying to set mach3 origin to be above my part, solidcam sets it inside my part at origin.
    Attachment 335050
    Feb 2016
    13
    I figured it out finally.. Can't believe it took me 2 weeks to find that i just have to manually input the machine position.
    Mar 2014
    1131
    Would you share how you made it?
    I don't know mach3. With solidcam it is far easier to draw your stock size around your part, make it transparent, create an referance origin where you want your tool origin to be, and then bring it in to solidcam. Choose the origin you made. The transparent stock. And your part obviously as the target.
  1. Need help starting point and ending point wont contact
    By miketola in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2014, 08:04 AM
  2. I need a starting point
    By G02 in forum DIY CNC Router Table Machines
    Last Post: 03-13-2012, 12:05 AM
  3. VM5 Toolpath starting point
    By Prboz in forum Visual Mill
    Last Post: 11-06-2008, 11:07 PM
  4. here is starting point for the new guys
    By spider in forum Casting Metals
    Last Post: 09-10-2006, 06:10 PM
  5. Home, zero, starting point...
    By saturnnights in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-14-2006, 09:57 PM
